Phone Mount
So I’ve had to e idea of 3D printing a mount base that would slot into the grill in the bottom left of this photo and be held by friction. No adhesive, no drilling, no fuss. Anyone have the means and motivation to try this?
Bomb proof I think. Location shouldn’t (?) be a problem with the airbags
How did you mount? Looks like you screwed into side. I see the ram mount… are the other parts RAM? Linenans post above didn't work for me. I mounted with self adhesive mount and it pulled away after two separate tries (replacement mounts). I love RAM but dont want to screw into dash. Still looking for an alternative.
I used a Ram Mount ball mount system. I purchased the 1” ball mount with adhesive and placed it on the flat side behind the media screen. There are flat areas there that seemed to work well . I then used some of the mounts to bring my Garmin nav to the right side of the screen.
Picture of the Garmin mounted? Please?
It’s screwed into the top hole of the handlebar. Super solid and not going anywhere. If I had better tools I could get a sharper bend angle and have less encroachment on my field of view
The “arm” part is this
Not a cell phone mount but would work as one..........
My Radar Detector mount used the adhesive disk, which lasted a very short while after the sun stated shinning.
I removed the speaker grill (pulls straight up), used a grinder to grind down the ribs and epoxied a metal plate (outlined in yellow) to the underside. I mounted a rubber coated magnetic base (fabricated pedestal) to the cell phone mount. The cell phone mount was called a "goose neck" flexible mount (which I removed). It has approx 5lbs of holding power, which is plenty for my needs. A stronger magnet would increase the holding power.
Weathertech Russian doll works quite well. No drilling, no tape, no long power cords, just one less cup holder.
Once you subscribe to "On X offroad" app you'll never go back........... My Garmin has been gathering dust for a year now. There is a fee but that fee gets you a pretty decent discount with many off road venders.
I paid for the top plan I think its 99 a year or something like that. Used the coupon for the methods I bought and that saved me a little over $400. Well worth it.
After trying a RAM mount systems with an adhesive base that kept pulling away and another display mount system on Amazon that did not fit my FE, this cup mount works and I love it. Plus its roughly $30, much cheaper than others.
The wire holder can either be moved to center over cup holder and a can fits perfectly into this or possibly a Starbucks cup, or it can be moved outside as seen in my picture to allow for another drink/ or plastic cup.
This is the cup mount system
Idk why y’all have to have the cell phone right at eye level looks like you’re driving for uber. My cell phone goes in my glovebox while i’m driving. The LC beeping at me every 30 seconds is enough distraction for me. I can make and answer calls with carplay and anything else can wait.
I had Offroam in my 2019 Tacoma - I may have been one of the early customers back in 2019.
The mount is fantastic. I am glad to see they've got a mounting base for the 250:
@basedMDcruiser - it's a personal choice, but here are a couple of points. They might not be a big deal to some, as you say you're happy to keep the phone in the glovebox.
  • Access non-carplay functions - many work apps just don't mirror.
  • As a secondary display, you can have your music controls always at your finger tips while maps are on display in your LC or vice versa.
  • Just convenience of glancing at your phone to triage a message or perform similar quick tasks - i.e. is this something I need to pull over and deal with or it can wait. If you are working from the LC this is a big deal.
  • Take a video call :) I might not be looking at the phone screen, but the other party can see me and that's not possible without a good mount.
And the screen tech in the LC is frozen in 2024... but if you get a new phone in 2028, you will have access to whatever they come up with :) It's future-proofing your car.
On the 1958, I went in a very similar direction to what fellow member Lineman did...used an assortment of Ram Mount parts I had in the garage and picked up a base mount on Amazon that has a 3M style tape. Placed it in the area that the charging mat would be on the LCLC and FE. I agree that with CarPlay a mount isn't all that necessary but it is nice to have the option to charge w/o the phone sliding around!
This is what I used on my FJ, clamped to the drivers side pillar grab handle. It put the phone high in front of the pillar. For the Land Cruiser it might need an additional piece to get a good angle. So far I haven’t felt any need to to have a phone mount though, the center display is larger.
I think this is what I got: RoadVise® XL Phone and Midsize Tablet Clamp Post Mount for iPad, Note, Tab and more
They have variations with different clamps, holders, arms, etc. For instance:
found a pretty decent magsafe charging phone mount on amazon that works well. Amazon Link
it has a separate rubber adhesive which you then stick the mount adhesive to that allows me to put it in the perfect position and still stick very well. despite me having to pull it up and replace a few times for the perfect position and being partly on the softex material.
this position is much better in my opinion compared to the ones made for the LC I have seen (and bought) which block part of the media screen and volume knob because they are too far towards the center of the dash.
havent tested the charging speed but wouldve gotten it without the charging anyway. Just want to have the ability to use charging pad as storage if needed.
I canceled the automatic renewal on Gaia. I've had it for like a decade. It's good, but not user-friendly and they seldom update with anything useful. I'm going to give OnX a try this time.
I think someone here mentioned getting the Offroam mount? It looks nice but has been out of stock every time I checked.
2024-2025 Toyota Land Cruiser 250 Phone Mount
The Offroam mount is really high quality and super sturdy. I just wish it had a provision for a MagSafe charger to go into the holder.
I carplay my phone on X map to the main screen, doesn't everybody?
