I had the dealer put on BFG KO2's before I picked up my Land Cruiser FE. They are the same size as the stock (265 70 R18) but I am only getting 17mpg. I have around 2500 miles now and it has not changed. Any one else having the same issue?
First thing I did!Did you remove your iForceMax badge?
Got it. Commute around 23 miles a day in Eco mode mostly flat here in AZ. Because it is 100 and HOT out, yes I do run the a/c to keep it manageable. As far as accessories, just the stock roof rack that comes on the FE. Thanks for the break down!Is 17mpg a value you are calculating or is that the total average? Personally, I am planning on resetting that total average again when i get to around 1000mi.
Tires are only 1 piece of the gas mileage puzzle. so it's hard to say why you are getting lower than expected mileage without considering every variable:
Here's some things to consider that impact gas mileage:
- tires
- how you drive (lots of acceleration and braking vs expert level Prius hypermileing)
- short drives vs long drives (short 5-15 minute drives are absolutely terrible for gas mileage)
- freeway speed vs slower 2-lane highway speeds (i.e. 80mph vs 55mph is a huge difference)
- winter - both harder on mileage + gas mixtures are worse (probably not applicable right now)
- summer - blasting AC, idling (applicable right now!)
- terrain - uphill bad, downhill good!
- exterior accessories - roof rack, cargo box, loaded bike rack, etc
Agreed. I thought it would run exclusively on battery more than it does in stop and go traffic.To a point up-thread, this is not an aerodynamic vehicle. Air drag has an exponential effect on efficiency as speeds increase, even more so if you're dealing with any kind of headwind or crosswind, so keeping it to the speed limit on the freeway will cut down on consumption.
I'm a little let down by the lack of hybrid boost I get around town, I was hoping that would kick in a lot more taking off from lights and stop signs than it actually does. It's a surprisingly stingy system.
Hybrid control unit is very conservative to not let battery level get low, since it uses the hybrid battery&motor for other "essential functions", most notably, cranking the ICE.Agreed. I thought it would run exclusively on battery more than it does in stop and go traffic.
I’m only getting 17 as well. I reset mileage as soon as I got it, initially I was 22-23. But around my home with slower speed zones and some hills ect mine has settled into 17 at bestIs 17mpg a value you are calculating or is that the total average? Personally, I am planning on resetting that total average again when i get to around 1000mi.
- tires
My FE started like that. Around 1800 miles on it now and closer to 21, mixed city and highway. Think it has to break in a bit, but also the FE with the roof rack doesn’t do quite as well as the 1958Im also getting only 16/17 mpg. Its a FE.
4 tank fillups so far. all Premium gas.
Ive done city driving, long highways trips. All about the same mpg. And I'm still using a soft foot as its new.
Any ideas? Many/most here report 20's. Could it be California summer blend gas?
Im about ready to go back to dealer. This MPG is no better than my Tacoma
