Post your results here....
That report looks like the standard analysis.
I wouldn't trust Blackstones fuel dilution numbers. They use a method that is basically a guess. Use polaris labs if you want that number to be more accurate.View attachment 13994Thought it would be nice to see what other LC owners reports read. I plan on getting another report at 5000 miles to see if the Fuel % drops. My replacement oil was... Valvoline Restore & Protect full synthetic 0W-20, with toyota filter.
Standard... $35 bucks... As they already had my money about 3 weeks before the results... They have no reason to lie...
Don't know where this aggressiveness is coming g from. Blackstone is fine and I never said otherwise. All I said is if fuel dilution is not measured accurately there. They do not have the very expensive test machine to do it.Standard... $35 bucks... As they already had my money about 3 weeks before the results... They have no reason to lie...
Did someone rip you and No15... off in the past and make you think all Labs are Full of Shit?
Guys... It's just data... No one is trying to prove a point!
Take your Tin cap off!
Sorry, Not being aggressive... But they have the machines and correct equipment. Unless you work there and would like to explain how bad and or old their equipment is...? What data do you have that suggest they don't have the correct equipment... ?Don't know where this aggressiveness is coming g from. Blackstone is fine and I never said otherwise. All I said is if fuel dilution is not measured accurately there. They do not have the very expensive test machine to do it.
You mentioned fuel dilution as a concern and I suggested a lab with the correct equipment.
ok you like to infer a lot of things based on little info butSorry, Not being aggressive... But they have the machines and correct equipment. Unless you work there and would like to explain how bad and or old their equipment is...? What data do you have that suggest they don't have the correct equipment... ?
So.... Is it the same data that is telling you use polaris labs... requesting you to wear a tin hat to prevent your goverment from reading your thoughts?
