OEM Side Window Deflectors - IN STOCK
micah
97
75
Ohio
Land Cruiser, Tacoma 2017
Has anyone had any luck recently being able to purchase the OEM side widow deflectors, part number 08162-60840 ? I know these deflectors have been out of stock recently. Thanks in advance.
Do they require removing the weather strip to install?
Yes, I believe it requires pulling loose the top section to install two clips for each window.
Any chance you or someone else would have or could get Toyota’s installation instructions? Thank you!
OEM visors are readily available to be shipped from Japan through resellers. Ordered mine here and received them within a week.
They were also kind enough to provide me with some translated instructions here.
Very easy and quick install once you figure out where the clips go (peel down the weather seal from the window frame, they mount directly to the frame and seal goes back over the clips).
Any chance you can take a picture from the inside (driver's seat) looking out and illustrate how the clips look? Do they block the view and stick out?
Here you go, you can see the clips a little bit but they don’t really bother me at all. The oem quality is definitely there.
Plus the added security not having to worry about them only being held on by adhesive & just flying off on the highway, or some not-so-do-gooder walking by and easily pulling them off is always nice.
Just ordered the OEM Side Window Visors yesterday from Toyota Parts Express:
I also ordered with them last week, called today to check status and they said they are waiting from them to ship from Toyota, they then checked with Toyota who listed them as out of stock. Please update if yours ships.
I definitely want these or something like it for our Cruiser. Anybody know if these are low profile? Also if there is any video circulating out there showing the install process? Much appreciated!!
