Need Wiring & Component Diagram for Digital Rear View Mirror from TIS
YotaPilot
23
24
Texas
J250
Hello all, can someone with access to TIS post the component and wiring diagram for the digital rear view mirror? Trying to to install a radar detector using a Blendmount with a mirror power tap. Don't want to break anything! Thanks in advance.
This is what I found on Blendmounts site under the mount I ordered this morning.
I don't know if this will help or not.....
  • Digital Rear-view Mirror.pdf
  • Option Connector (Dash Panel Camera).pdf
  • Rear View Monitor System.pdf
  • Q1 Map Light Assembly.pdf
  • Q10 Inner Rear View Mirror Assembly.pdf
  • Q11 Inner Rear View Mirror Assembly.pdf
  • Q22 Option Connector (Drive Recorder).pdf
  • Mirroor REAR VIEW MIRROR.pdf
Very helpful - thanks much!. Is there a diagram showing how the rear view mirror mount and cover disassembles? Not sure how to unsnap cover.
I tapped into the right middle harness (white plastic, red to red, black to black) for my Uniden radar detector.
I'd been trying to wire my Valentine One just under the mirror with a mirror mount. I assume the wiring behind(/above?) the mirror varies depending on trim & features.
Unlike users above, my RJ11 to red/black didn't match up with the white connector (mirror power) in the same red-to-red, black-to-black format. For me, red-to-red, and black-to-white/black twisted is the only combination I could find to give me switched power.
I've got a Vantrue dash cam going in next and am going to likely have to route it around the windshield, through the A pillar and to the fuse box. We'll see how it goes.
