Please note that this is not a "when should I use....." type of question. I am strictly interested in the vehicle's capabilities!
I am coming from an '18 JLU Sahara with the 'SelecTrac (?)' transfer case and a limited slip rear diff. This vehicle was the best I have owned for Northern MN winter driving. The Rubicon's lockers were only available in 4WD-Low, whereas my Sahara's LSD was available 24/7. I also very much liked the combo of Full Time 4WD/ AWD and LSD to keep me out of trouble in the snow.
My question is this: What are the parameters under which the center and rear lockers will actuate? Is it 4WD Lo only or do they work in 4WD Hi as well? Is there a speed limit above which they will not actuate?
I cannot imagine a scenario wherein the sway bar disco might be used in 4WD HI, but am curious - are there gear range and speed limitations here as well?
Thanks!
Thanks!
