Lighted OEM Running Boards on 1958 edition?????
MeteorCruiser
16
5
SoCal
2025 Land Cruiser
Hello All,
I have searched through most of the Forum and I have come up short. Has anyone been successful at adding OEM illuminated running boards to their 1958, if so, how? I have finally got a set of running boards and would really like to have them function with the lights. Any help will be greatly appreciated. Thank you!
It's a question of whether the cables for the lights are there. And if they are activated maybe? Some have reported only being able to find them on one side. If there, they would be tucked/taped up and plugged into a dummy plug. Let me see if I can find a photo of mine...
When it's tucked up and away you'll probably need to get under and search for it, here's one of mine hanging down after I removed the running boards.
The passenger side cable is present and secured via a clip to the frame, however the drivers side is nowhere to be found. I wonder if there is a "jumper" harness that plugs into another connector underneath the door sill?
