Land Cruiser Tire Upgrades?
Does anyone have information on possible tire upgrades with the 20" wheels. That is how my LC is optioned. 20' would not be my first choice, but it is a big hit to buy both tires and wheels to go to 18". I would like to see if I can put a bigger, more aggressive tire on the stock 20"
The Wildpeak A/T4W comes in a 275/60R20 which is a true 33 and could be a good choice.
I’d def get the standard load version and not the LT.
I would start with looking at 275/60R20s. That's a 33" (fits stock GX) and is a really common 1/2ton size (lots of availability).
hello, does anyone know if a 285/70/18 fits in the tire holder area?
One member here confirmed that 285/65/R18 fits (but sticks down a bit). It would be nice to have a list of what fits there as we try larger tires. For folks who don't want a rear mounted tire that's likely to be a tighter limit than the wheel well. (Although I'd still like to know the largest you can go without rub at full flex with the sway bar disconnected!)
Wheel size would be a tough variable in regards to max tire size.. width and offset will play a huge difference. Sounds like Westcott was in the 30et range for max fitment, where stock is 60.
I like those, and the offset would push it out a bit for a better stance. I've also been seeing the wheels below on '24 Tacos, but can't find a part number for them. They're 18" and 6-bolt pattern, but I'd like to confirm 6x139.7 and what offset is.View attachment 1852
That is the Tacoma Pro wheel. It is something like a 20mm offset. It will likely poke a LOT on a Land Cruiser.
New shoes! 275/70r18 +18 offset.
Slight rubbing at full turn on the passenger side. Looks like it’s a removable plastic piece.
Probably a question that can be answered quickly but if you change the outer diameter of a tire fro factory size,, is there a way to recalibrate the speedometer or does the vehicle do it automatically? Thanks
I doubt it will do so with out a programmer or reflashing at dealer .speed is the least of issues , it depends on how much larger you go , but everything from speed to shift points of trans
If it's the same as with the tacos, there's no real way to change it in the software. Even at the dealer
