My gut feel is the Turbo 4 will not be as forgiving as a normally-aspirated V6 or V8. Drove a turbo Subaru for years, but was always careful to allow it to warm up and cool/spool down. No issues. Will one be able to get 300K+ out of the turbo 4? Doubtful in my opinion, given the pressures and demand on the engine. Would I buy one? Sure! Do we really have a choice?Did you read the comments ? Within minutes lot of "turbo 4 can't be reliable, we need V6 or V8".
It might be a wash, as by 300K the battery will need to be replaced, at least once.Let's say within +300k you will have some issues (unexpected repairs). But even so I bet that you'll save much more on fuel with the 2.4T Hybrid.
This is a good point. Remember I have an EV. Anyhow there is a 10 years 100k warranty on the battery and with all this research and investment all over the planet I hope to see smaller, cheaper and overall much better replacement batteries in 2032. Wishful thinking ?It might be a wash, as by 300K the battery will need to be replaced, at least once.
Hopefully we will see aftermarket batteries in abundance. My worry is that battery chemistry/design is evolving so fast that in 10 years it will be markedly changed. Toyota says solid-state batteries are just around the corner. Been following info re replacement, and the success rate for repaired/refurbished batteries is not encouraging. I'm seeing prices in the $6K region mentioned for new OEM hybrid batteries, and of course out of sight for EV's. Presently Toyota is utilizing NiMH batteries in the LC and Tacoma, but how long will that continue? Actually a good thing in my opinion, as opposed to Li-Ion, which are fire prone and not so great in extreme temperatures, cold or hot.
I did some research on this. Might be biased findings but most people with Toyota hybrids have said the batteries lasted over 10 years, and averaged about $2500 or so to replace. Considering the fuel savings (and additional power), I'd suggest that's a good tradeoff.Question: How does battery age figure into the degradation equation? In our case we only drive about 3500 miles/year. I am beginning to question how advantageous a hybrid vehicle would be for us...
Good point. High mileage drivers will experience the most economic benefit. Capacity loss happens over time when the battery is charged and ready for service. The standard capacity loss curves apply as long as the charge level is service-ready at nominal ambient temperatures.Question: How does battery age figure into the equation? In our case we only drive about 3500 miles/year. I am beginning to question how advantageous a hybrid vehicle would be for us...
This is not much !Question: How does battery age figure into the degradation equation? In our case we only drive about 3500 miles/year. I am beginning to question how advantageous a hybrid vehicle would be for us...
A 10 year life for NiMH cells seems reasonable. I was estimating $100 per cell if I did the replacement myself. $2500 seems low and may reflect some folks using reconditioned cells.I did some research on this. Might be biased findings but most people with Toyota hybrids have said the batteries lasted about 10 years, and averaged about $2500 to replace. Considering the fuel savings (and additional power), I'd suggest that's a good tradeoff.
Toyota Hybrid Owners Speak Out on Battery Length and Cost
How long do hybrid batteries last and how much to replace? Hear from owners of Toyota Prius and other popular models.www.torquenews.com
The Tundra cab must be lifted off the frame to service the turbos, of which have been problematic.
And my '07 Tundra. By far the most reliable vehicle I've ever owned, which includes several other Toyota trucks/SUV's, and a few Hondas mixed in there. I won't mention how the Ford experiments went.The cab was removed on a few early ones to have better access for Toyota engineers to investigate the problem. The repair manual for replacing a turbo does not call for removing the cab.
As far as "proven"... the electric motor was pulled straight from Tundra. I'd be pretty comfortable about the 8AT, transfer case, and axles. Engine is in the sorta category. It shares a lot with the transverse mounted T24, but there are new parts for the longitudinal iteration (turbo, intercooler setup, various bits accessory bits). It is also a new manufacturing facility for the T24 engine, so there will be some manufacturing related teething issues. Sharing so much of the platform with LC300, LX 600, Tundra, Sequoia, and the upcoming Tacoma does mean there is an economy of scale of sorts when it comes to quality, though. Minimizing those iterations is usually a good thing for quality.
At the end of the day, it is a little risky to buy a first model year. I did it with my 2010 4Runner and it was flawless and the same thing with my 2023 GR Corolla (so far).
