Installation of Roam Rugged Case on First Edition Roof Rack
PixelMagic
162
428
Pasadena, California
Land Cruiser First Edition
Thought I would share this in case it helps someone thinking of this product.
Installation of 95L Roam Rugged case on First Edition Roof Rack using the 95L Roam Rugged Mounts.
  • The First Edition Roof Rack needs 5/16" carriage bolts: the Roam carriage bolts are too small for the T rails.
    • Use 5/16" diameter by 3/4" long carriage bolts. If the bolt is too long, it will hit the bottom of the case.
  • The Roam Rugged Mount slots are just under a mm too tight for the proper sized carriage bolt, but it is easy to widen slightly with a Dremel. Be sure to Dremel enough to let the bolt screws pass easily.
    • These pictures show where to widen to accommodate the bolts for the Front and Back Mounts.
Front
  • For the back, use a Torx wrench to move one of the cross bars to the back.
Very secure and lockable clamp mechanism at either end.
Nice set-up. Thanks. Now all we need is a nice functional (flat steps/rungs) folding ladder that won't eliminate access to the rear window. I wish they'd put a sliding rear window (a-la-4Runner) so a Wescott ladder would work. Hoping some after-market company will develop a good set-up soon.
    • View attachment 7242
Front
Tire specs and name please. Any rubbing when off-roading?
