First Edition Roof Rack Assembly and Install (2 parts)
@DctrEvil do you have more photos of how the rack was packaged by any chance? I’m going to ship mine to someone and I’d love to see how the pros did it!
The first photo at the top of this thread shows how amazingly Westcott Designs shipped the rack. They are real pros and have an expanding foam packing machine, so it was the real deal! I just shipped my roof rails and crossbars to an out of state buyer, via UPS and I packed with multiple layers of bubble wrap and then slid into a long box. It arrived just fine, good luck !
You are a Godsend! I just picked up a takeoff roof rack from a forum member here and was searching for the install instructions online! Thank you so much Sir!
Thanks @Dr Bob . But I was looking for a way to buy just one additional crossbar for the FE roof rack. Likely not available from Toyota so was hoping to learn who the rack manufacturer is.
You can buy an extra slat now. I just got and installed mine today. They are still scarce or back ordered so I think I waited for mine about 2.5 weeks after ordering and before it shipped. I think I paid ~$70 for mine.
Part number in following photo:
Wow, thank you for this...Where did you get the x-bar mounting screws or do the screws come with the x-bar?
The mounting screw comes with the OEM rack (it covers the pre-drilled, pre tapped, hole for the missing cross bar) so all you need to do is unscrew it, put the new crossbar in place and re-tighten original screw.
Thank you...that's very interesting Toyota did that...glad I don't need to source the screws for my OEM installed rack (y)
Hi all. Anyone here knows what eyelets would fit the FE roof rack? Also looking how to mount a set of Maxtrax and Rotopaxs. Not sure if the Prinsu or Front Runner accessories would fit the FE OEM rails. Thanks.
The roof holes for the 2024 landcruiser are exactly the same as my GX 550 overtrail. When I replaced my roof rails the landcruiser OEM rack , Prinsu and Westcott all fit without any drilling. You have to remove the rails first. I chose the Westcott because it looked the best and is low profile and makes hardly any wind noise.
I used Maxtrax's Universal Flat Rack Mounting Kit in my LC FE with OEM rack. Comes with everything you need to mount it, works perfectly with the OEM rack and holds up to 4 boards. Additionally it has provisions for adding a small padlock(s) to secure the boards in place. Only slight negative is cosmetic in that, when you are not carrying the boards, it looks as if you had 4 small antennas mounted in the rack. I jokingly call them my anti-mind control antennas 😉
I am in process of replacing my cross bars with FE Roof racks. With the FE Roof rack installed, how does the sunroof open?
The OEM FE roof rack doesn't cover the sunroof, so it opens normally.
Does anyone know why Toyota shipped these with only four slats instead of five?
I figured (incorrectly) it was for weight reasons since the rack dynamic load rating is already just passable at 165 lbs... if each slat was 10 lbs that would be significant. But I just picked up the fifth slat and it feels like maybe 1 to 2 lbs. Label just says 1 for the weight. I can't imagine the extra slat significantly contributing to wind noise or fuel consumption either. It did cost me $63 so maybe just costs savings. It looks better with the 5th slat. Also, I can't imagine requiring the 5th slat however if I only had four I would move one of the center ones to the end; the plastic endcap at the front and rear do not have anything to secure against.
Strange about the VIN number thing, for 2025 this rack is an option on all LC/LC, yep it still has only 4 slats, see image
