Hybrid longevity
jhiller
Sep 17, 2024
5
4
michigan
2024 LC
Anyone else have concerns about the longevity of the hybrid system in the new LC ? For many folks LC's are acquire and keep vehicles and I wonder how the battery and electric system will age ?
Just consider the battery a maintenance item like a timing belt replacement. By the time the battery needs to be replaced, it won’t be that expensive. Toyota knows hybrids better than anyone
Many years ago when the tech was new, having a battery go bad in a Toyota hybrid was the kiss of death. I knew someone that was quoted $10K for a whole new battery, and this was +10 years ago. The car was worth maybe that? Now, they replace the 'bad cell' and not the whole battery, or replace the whole thing with a reman'ed battery (bad cells replaced). There is a cottage industry of folks that do this as well on older hybrids. Drastically cheaper, think >$1000 vs. $1,000's. The battery tech has improved by leaps and bounds as well.
On longevity of Toyota hybrid, we’re still driving our 2012 Pirus with 215k miles on original hybrid battery pack and so far, the only the major work has been brakes at 185k and water pump at 205k. Battery pack is still holding decent amount of charge and averaging 48mpg on regular commute.
When battery pack does go, we’ve got $2k budgeted for replacement at our local shop and refurbished battery pack is readily available.
The reason for my Cruiser is because someone totaled my 17 Camry Hybrid with 174k. I owned a Prius before that. Toyota batteries last much longer than other hybrids, and are serviceable (can replace cells) as others have stated. I would not worry about it.
However, what you can control is ventilation to the battery. IIRC, just open your rear doors and look at the vents behind the seats on the side. You'll want to check the "filters" or "screens" in them annually or semi annually. They can get clogged with dust. Do this and you should be good for a long time.
Notwithstanding battery life concerns, I’m not sure why we should be overly concerned about Toyota electrical systems. I owned my last LC for 22 years, having bought it new. Over that time period, I paid a fair sum of money to replace worn parts but very little on electrical items.
My dad always viewed car options / features as “one more thing that’s going to break”. Though I was glad that the 1958 lacks the cool box, it was not because I was worried about its longevity.
I sold a 2012 Toyota PHEV Prius I had for 12 years and over 150K miles to get money for the LC :giggle:. I think it was a first generation plug in at the time and it was flawless. Replaced nothing but fluids and consumables on the maintenance schedule and never had a single issue.
If I remember correctly, the LC has an 8 year, 100,000 mile warranty on the hybrid sub-system so I am not very worried. Keep in mind the Prius hybrid system is very different than ours. The I-Force Max was specifically selected for robustness and the ability to still use the well proven drive trains from its traditional 4WD/AWD systems. (gear boxes, transfer cases, drive shafts, differentials etc.)
If you haven't seen it already, the video link below from Toyota provides a nice summary of how the two hybrid systems work, and why they are different.
Toyota Hybrid Video
Yup, I don't think it's an issue anymore. Different story if the tech just came out.
