Where did you mount the antenna?Controller is installed! It looks very much factory.
I got the newly released ICOM IC-2730B which is the black LCD edition. It's perfect!
Which diameter grommet did you use?
Edit: it’s a 5/8 inch grommet.
How did you sneak the positive through?
How do you get a cable into the pax or driver side fuse box? I have the cable through the firewall but can't figure out how to get it into the fuse box.If you are already pushing a coax through the firewall, why not add a wire and tap into the Dvr's side fuse box.
What bolt is this grounded to?
