Can you show a pic centered? How did you affix the bracket to the grill?Good call! I wondered about that but your response "seconded that thought". I centered it. Looks good and no holes.
in CA this is the only licensed seller for adhesive plates License Plate WrapPosted in another thread... food for thought. I've used these on two cars with no issues.
Custom License Plates - Adhesive license plate replica
Custom License Plates. Order online USA license plate replica stickers. Easy & simple way to avoid drilling your car's bumper.customlicenseplates.us
Cosmetic problem with this is that the height of the plate wrap is larger than the height of the bumper so one would have to choose to wrap it around the bumper in the bottom or to split the difference top and bottom. Either case I think it wouldn't look good. The rigid plate ain't much better but I think the floaty look is less objectionable to my eye than the wrapped around the bumper look....in CA this is the only licensed seller for adhesive plates License Plate Wrap
Today I was able to use zip ties (24 inches) and adhesive foam (1 inch place on the bottom and between the screw holes on the top) to secure the license plate holder to the bumper. See photos. If u can live w 2 zip ties that look like it might be part of the bumper and that the bracket isn’t completely flushed to the it…this hack works for those of us that don’t want to drill into the bumper.I posted this on another thread w same topic Front License Plate Bracket Install --
“I live in CA and as others have mentioned front plate is required. The dealer provided me w a front plate bracket (see below). But I also couldn’t get myself to drill holes into the bumper. So I decided to stick a 1 inch foam adhesive to back of the bracket to make it flush and used zip ties to attach it to the bottom grill (see photos). In another post I saw someone mention to put it in the passenger side something about engine temp (see link. Front License Plate. ) As u can see from the photo the LC FE has a front camera and the bracket does not obstruct the view. This is completely removable without permanent damage to the bumper. Unfortunately I added a bar light to the bottom grill and had to remove the plate. I’m trying to figure out another way to get the bracket on the front grill.”
