First offroad, el. 13,124’ [Summit County, CO] - Compare/Contrast 5th Gen 4Runner
b407driver
🏆 LC of the Month
Jun 7, 2024
281
357
Colorado
2024 LCP Trail Dust
After 2+ weeks of ownership, I finally had the opportunity on 9/20/24 to get my LCP offroad and generally compare the ride and offroad systems to the outgoing 4Runner, which I drove for 9 years. If I were a hyperbolic YouTuber I’d title this thread “First LandCruiser up Santa Fe Peak!”, give myself a little trophy, and include a ridiculous picture of me jumping in the air next to my ‘rig’… but alas, I digress. Only ‘mods’ are 285/70r18 “E” Toyo Open Country on ’24 Tacoma 18” TRD rims (+45 offset, 28.75lbs); added FE skidplates and FE rock rails. Was a gorgeous day, so I’ll include a couple pics of both the LC and the trail. Haven’t seen many in-depth on-trail performance/feature reports, so will go into some detail here.
The route up Santa Fe Peak starts right in the town of Montezuma, and pretty immediately starts switchbacking up 2700’ in 5 miles (23 or so switchbacks, if I counted right); took about an hour to get up. Santa Fe Peak isn’t particularly rigorous or technical (no big ledges, etc.), but you do need some decent ground clearance, like in a slightly lifted 4Runner, for example. Which I no longer have. The trail is a bit shelfy and off-camber, and a few of the switchbacks felt pretty sporty on the downhill run; only had to do three 3-point turns. It really feels like the LC has a tighter turning radius than the 4R, but it’s honestly probably related to the full-time 4WD system in the LC not binding in 4 Low. I did not mind the light steering feel. This is my first full-time 4WD vehicle, and so far, I am a fan.
On the way up, I was watching the turbo and hybrid gauges, just to see how this new drive system would handle the high-altitude climb (more variables than a simple IC engine). I was quite surprised to note that below ~12,200’, the turbo and hybrid system rarely kicked in, only when needing to get up a short, very steep portion of the trail, and only very briefly. Considering the considerable elevation and temps (60-55°F), this surprised me. Also, about halfway up the hybrid battery was nearly at max SOC, ~7 bars; (started at 4 bars). At around 12,500’ the turbo started kicking in, and from then on did so pretty regularly, as needed. This seems odd to me, as there wasn’t a big change in terrain that should have warranted it. The hybrid only really kicked on for a second or two max, never for any extended period. This also surprised me. Fuel economy on the way up? 5 mpg.
No more Trail Dust, this is Fall Tundra!
As far as the offroad systems go, I stayed in 4 High with the Center un-locked until around 11,000’, at which point the road surface loosened and I engaged the center locker (in no way did I ‘need’ to, yet). Further on as the surface got more irregular around treeline, I engaged MTS Auto, simply to prevent tire spin from chewing up the trail unnecessarily. [I did not air down (38psi), I did not use DAC/CC, I did not use the rear locker, nor did I disconnect the swaybar.] This LandCruiser simply climbs like a goat, there’s just no other way to put it. I assume it is due to having more articulation than the 4Runner, and the ride is much more comfortable because of it. No sharp jolts, the stock suspension really dampens the ride without making it feel ‘boaty’, and at least for crawling, it seems much better than the 6112/5160 TRD Pro suspension on my 2016 4Runner (perhaps I’m getting soft in my old age). The ride at 38 psi was at least as comfortable as the 4Runner aired down to 20 psi! I can’t wait to get to the desert to find out the other side of this coin, e.g. high-speed/washboard. What Toyota got 100% right with this new offroad platform that was previously lacking was designing a fenderwell that can accommodate 34” tires at full articulation. That was long overdue considering the competition.
IMG_5471_LR_sRGB-.jpg front rear
The high point of the route is 13,124’ MSL, with gorgeous views down into Peru Creek on one side (with Grays and Torreys towering 1000’ above), and Webster Pass on the other, 1000’ below. Quick aside about the Trail Dust color, which was not my first choice, asI initially thought it looked quite yellow in pictures. The color is seriously growing on me and looks more gold to me, and in my brain the color is now ‘Fall Tundra’, after this trip.
Looking down into Peru Creek Looking down onto Webster Pass
For the ride down I immediately engaged 4Low, and as on the way up, the LandCruiser also descended like a goat. Tires stayed planted, and it never felt like a tire was quickly slipping down a rock and bashing into a low spot, which was not uncommon with the 4Runner. Clearance seemed to be more of an issue on the descent, I assume because the terrain is harder to see than going uphill. Tire placement became more important, and despite not dinging the FE skid plates on the way up, I definitely heard three contacts on the way down (only felt one). The LC could certainly have a bit more ground clearance out of the box, especially in the vicinity of the front crossmember. The trail cameras were a refreshing benefit of a modern vehicle, thus never had to worry much about tire placement in relation to the drop-off. Visibility out of the LandCruiser is excellent; the sloped hood makes a huge difference (my prehistoric 4Runner shows more hood out the front than terrain!), and the view out the side window/A pillar is also much better. I think it's a big deal that MTS can be used in 4 High, as the 4Runner's ATRAC system is limited to use in 4 Low; MTS makes virtually no noise compared to the incessant chattering of the 4Runner’s ATRAC system. The inclinometer is fun to scan, albeit occasionally alarming. One question: Why no altimeter, Toyota?
IMG_5516_LR_sRGB-.jpg IMG_5501_LR_sRGB-.jpg IMG_5507_LR_sRGB-.jpg IMG_5524_LR_sRGB-.jpg
Now, the elephant in my room, anyway, and probably my primary beef with the new platform: Engine Braking. Or lack thereof. Nearly a complete lack thereof, compared to the 4Runner’s V6. I haven’t heard anyone talking about this! Even for on-road driving, manually downshifting provides little braking effect. We tow a mid-sized teardrop trailer, and I’m having a hard time envisioning how this will work (read: I’ll have to use much more brake pad). This is probably the most unfortunate part of this purchase for me, as we wanted to move to a vehicle that tows better (I’m sure the LC does so in regard to power/torque, despite TFL’s inane missteps with the tow/haul software). I can only hope that the lack of engine braking might have something to do with a designed break-in period which anecdotally might end at 1000 miles. Can the hybrid motor be used for engine braking? Total trip fuel economy at the bottom? 7.9 mpg, so maybe got 11 on the way down.
So, between the previous articulation/tire rub test I recently did and this first outing (no tire rub here, either), I am incredibly impressed by how much better the LC is compared to the outgoing generation of the 4Runner. I honestly did not expect this, I just assumed it would be a more modern take on an established platform. It is certainly that, and more. Yes, I know they are historically two different vehicles/markets, but now that four Toyota/Lexus vehicles are built on the TNGA-F platform, they’re all coming together with little more than design and creature features to set them apart. Yes, the new 4Runner should perform identically (albeit with predominantly part-time 4WD), so if nothing else, this sample of one should at least give those waiting for the 6th Gen 4Runner some info on what they are still waiting for. It will be a great vehicle, just no longer for me.
Cheers, Jeff
[EDIT: Not sure why that last image also shows up as thumbnail, doesn't show up in 'Edit' pane; also clarified 4High statment]
That lack of engine braking is disappointing to hear and will likely not go away, unfortunately. My wife has a 2 litre, 4 cyl. turbo Audi Allroad with paddle shifters. Shifting down is almost imperceptible in terms of engine braking going downhill or into a corner. If not for the tach, you'd barely know the paddles were working. In fact, in cruise control the vehicle applies brakes (!!) going downhill on the highway. My Tundra on the other hand has excellent engine braking and relies on gearing down quite impressively to control speed.
Great write up! Also.. no mention of the downhill control assist? Am I assuming you just used that under the MTS label for the downhill part?
It is disappointing, but I half expected it due to the 4-banger (no surprise, really), just didn't expect how useless it would be. TFL's Ike video touched on it, but they didn't really discuss it (they should have), and instead chose to trash the tow capabilities due to their incompetence with the software.
Didn't use DAC or CC (all manual throttle control), thanks, I'll edit the text to reflect. Despite the above comment re: lack of engine braking, 4 Low in 1st/2nd was pretty adequate for descending steep grades, though did have to apply the brakes a few times as the revs got too high on a super-steep section. The 4Runner almost never needed brakes in 1st (4 Low).
Great report. Some of the best photography I've ever seen on a ride report. A lot of those passes may be closed for the season after this weekend as they're expecting snow in the high country. Thanks again!
As far as the offroad systems go, I stayed in 4 High until around 11,000’, at which point the road surface loosened and I engaged the center locker (in no way did I ‘need’ to, yet). Further on as the surface got more irregular around treeline, I engaged MTS Auto, simply to prevent tire spin from chewing up the trail unnecessarily. [I did not air down (38psi), I did not use DAC/CC, I did not use the rear locker, nor did I disconnect the swaybar.] This LandCruiser simply climbs like a goat, there’s just no other way to put it. I assume it is due to having more articulation than the 4Runner, and the ride is much more comfortable because of it. No sharp jolts, the stock suspension really dampens the ride without making it feel ‘boaty’, and at least for crawling, it seems much better than the 6112/5160 TRD Pro suspension on my 2016 4Runner (perhaps I’m getting soft in my old age). The ride at 38 psi was at least as comfortable as the 4Runner aired down to 20 psi! I can’t wait to get to the desert to find out the other side of this coin, e.g. high-speed/washboard. What Toyota got 100% right with this new offroad platform that was previously lacking was designing a fenderwell that can accommodate 34” tires at full articulation. That was long overdue considering the competition.
View attachment 12355 View attachment 12361 View attachment 12362
View attachment 12356 View attachment 12357
View attachment 12364 View attachment 12360 View attachment 12363 View attachment 12365
Cheers, Jeff
[EDIT: Not sure why that last image also shows up as thumbnail, doesn't show up in 'Edit' pane]
Fantastic writeup Thank you for sharing.
I’m also curious if you tried the DAC or why you didnt?
Didn't get too much snow here, just hiked up to 11,500' and there was just a bit in the shadows. I'm guessing a few days from now it'll be mostly gone, as it's supposed to warm back up for a bit. That said, the high-elevation wheeling season is indeed about done!
chris_in_phx, didn't need DAC or CC, and had tested it in the previous (video) tests I did. I think I'd welcome using it on something like the Red Cone descent, but coming from the 4Runner I've found many reasons to avoid it, the main one being that the 4R won't keep a consistent speed, it constantly jerks back/forth (noise would be secondary). The LC's system works as it should, and had I needed it, certainly would have used it.
I live in Denver and am on a two week trip through the Rockies. My trailer weighs a little over 3000 pounds. This thing tows so well over the passes. I have zero issues accelerating uphill going 70 miles per hour. Temperatures do not even budge. Granted, it’s not summer but it’s impressive to me. The trailer brakes were easy to figure out. I’m not sure why people were having issues. Engine braking could be better, but my trailer has brakes so that’s beneficial. Can’t have it all! Super great write up. I’ve had mine up Kingston peak, Argentine pass, and quite a few others. With a lift kit I don’t really have any complaints and the vehicle continues to impress me compared to a 4Runner.
View attachment 12469View attachment 12470
Good to hear. Sweet trailer!
How much lift did you do? Looks like a happy pup!
Awesome write up, thank you for sharing! Trail Dust looks awesome, I’ve yet to see one in person. As to the engine breaking, I do believe that pressing lightly on the breaks to maintain downhill speed should engage the hybrid regenerative breaking in the transmission rather than using the wheel breaks.
Although I can't say I 'tried that', I certainly was light on the brakes while descending for much of the time. If it was using regenerative braking, I certainly couldn't tell, and ironically I had less SOC in the hybrid battery at the bottom than I had at the top. I have to assume the ECT (or whatever they call the brain for this hybrid system) is functioning differently during the break-in period.
Okay so if you guys wouldnt mind helping me here… im relatively inexperienced to these functions on toyotas; i have lots of experience with engine breaking on my previous F150 when towing a 28’ travel trailer and I used DAC a few times driving downhill trails in oregon (not towing of course).
Is there a reason we would use Engine breaking vs DAC on a slow downhill crawl?
Cheers, Jeff
Engine braking seems to work ok downhill at highway speed, don't know about low speed on trail. Hit the brake and the engine kicks in.
It definitely changes over time. I’m just under 4,000 miles and it has slowly used more and more hybrid and running for longer periods on battery, I had a few miles of light load driving on mostly flat at 45 MPH entirely on battery this weekend, was really surprised, and the MPG keeps improving. Got an estimated 25.5 MPG yesterday on a 50 mile trip ranging from state forest road, back roads, steep mountain climb and decent, hilly, and interstate between 65-75 MPH.
