- Moderator
- #1
Contained in this post:
Air Compressor Install
Lighted Door Sills
“TOYOTA” Center Caps
Air Compressor Mod: Pic A/C - Viair 485C
Yellow dots are factory bolts/holes
Mounting plate, used some stand-offs under the bolts to make it level
Compressor mounted
Switch is from "CH4X4" (cube size)
Air tank mounted, it's tight but it fits
Chuck, pressure switch installed. I use a small tank, not for air storage volume but to take advantage of an air pressure switch. That way the compressor doesn't run non-stop. I also use a "pressure relief valve" in order to not burst the tank.
Passenger side Pwr Distro box, corner cover removed showing the main feed and starter cable lugs. At the top of the pic are the ribs that I removed in order to put the extension in.
Ribs removed
Paper template of the new buss bar extension
Stainless Buss Bar extension, 1st bends
Stainless Buss Bar extension, Finial crimp on to 6 gage wire
Stainless Buss Bar extension, mounted
Stainless Buss Bar extension, with OEM cover back in place. You can see the red 6 gage wire along the left side of the PDC, it's routed to the area in front of the air cleaner box
Circuit Breaker and Aux Buss Bar mount
Yellow dots are bolts/screw, Red dots are tabs.
Door weather stripping must be pulled away 1st (Yellow dots) then the side panel can be pulled off (yellow dots are approx where the plastic clips are, the Green dot is a plastic hook that must be inserted 1st when you reassemble.
Pull straight out on the switch panel for removal. I spliced into the illumination wire (green wire coming out of the rheostat and actually spliced in where there was room).
Pushed the switch and the air compressor works like it's supposed to! I used a fuse tap in an empty ACCY slot to power the Air Compressor switch (which in turn energizes the relay).
Lighted Door Sills Mod: Took about 15 minutes, Yellow dot is the wiring plug (passenger side is in the same location) a hook tool is the best tool to unlatch the blanking plug. The Blue christmas tree fastener stayed in when the OEM sills were removed, you will need to remove it before you install the lighted sill (new ones are already mounted in the new sill).
Center Cap Mod: Bought some Center Caps took them apart, painted them with "Ford Dark Shadow Gray" touch up paint.
Lighted Door Sills
Compressor mounted
Ribs removed
