DV8 Front Bumper dropping soon!
Just ordered mine today
Can't wait to see how it comes out and your recommendation to do this to mine or not. My LC should be here about the time you get this completed if you get on it.
If we were a bit closer I would offer to help since you stepped up and will advise the rest of this.
What winch does it use from Warn?
Thx for doing this.
They recommend the evo line from Warn . I am thinking the middle size with rope should do the trick
I am doing a wireless remote that way I donโ€™t have to run wires for controllers
As long as there is manual operation when the wireless goes bad for any number of reasons I am sure it can be.
You won't be sorry with the Warn, you may know this already.
I am excited for you this is going to be a great mod and adder to your LC.
When you order the bumper from their website, it provides all options. The winch you can add in is DV8 Off-road 12,000 lbs winch / Synthetic Rope $709.99
Is it good just like warn ?
I donโ€™t know , I know warn for many years , parts and service will be better. I donโ€™t like disposables I am a recycler.
This is probably the best looking solution Iโ€™ve seen and I think the price is fair. Iโ€™m very close to pulling the trigger, but have some concerns about the significant added weight of the bumper plus a winch. In addition to some over landing and offloading I spend most of my time commuting on highways and wonder how this would affect front end performance, airflow, and even they already poor mileage?
The total weight of this DV8 bumper+winch is about 120 lbs. This combo is super clean and most lightweight comparing to full bumper-brush guard + winch.
We expect lower mpg for off-road rig. That happens across all vehicles
You are probably correct . I may have to add the Westcott lift kit or front at least . I will see
Does anyone know where toyota recommends power supply for front winch. I assume I will have to run wires from battery in back left to front with a junction box to the winch
i beleive there is a high current terminal set in the engine bay for jump starts look for that.
There was a good post here somewhere a few days ago, maybe jump start will find it.
The manual is in the maintenance area.
Page 620 covers getting a jump start. There doesnโ€™t appear to be anything on jump starting another vehicle other than donโ€™t use the same terminals you use for getting a jump start.
Those specifics were not relayed to me. Just given a discount code: dv8cruiser
Let me know if itโ€™s stackable.
Thanks much for your discount code!
Would you share how to wire the winch? Connect to the rear battery or to the jump start pin in engine bay ? Thanks in advance
I am about pulling trigger to order the setโ€ฆ
Unfortunately, we have not wired the winch up yet. I have seen others online wire it to the rear main battery.
