Dash lights came on today
RoundRock_Cruiser
43
81
Round Rock TX
2024 Land Cruiser, 2023 Corolla, 2004 4Runner
Stopped at harbor freight to pick up some stuff and before I could get out of the parking lot, the dash lit up with a myriad of error messages telling me to take the truck to the dealer. It’s Friday night & I have to wait until Tuesday to take it in. I’m nervous that this will become one of those situations where the car is with the dealer for several weeks as they try to figure out what the issue is. I’ll post updates as they come out.
I had something similar happen to me, Try disconnecting the 12v battery neg cable and the little monitoring plug that's right beside it, then charge the 12v battery. after I did that and hooked everything back up, no more messages and no more issues.
If you disconnect the 12v battery (and reconnected it), if you have a powered rear hatch you will have to re-initialize it by manually pushing it shut, then lock should suck it the finial inch, then simply push the "open button" like normal. You will also have to put in your radio code (that's what I call it) it's the code you put in the infotainment screen when you first took possession.
I’ll give It a try tomorrow. Thanks!
