BFG KO3s for 20” wheels
CB3
πŸ“› Founding Member
Aug 7, 2024
36
16
CO
LC
Tirerack.com is showing KO3 to be available in LT275/65R20 size. Anyone know if these will fit?
Almost certainly. 275/70R18’s fit well, they’re as wide and slightly larger diameter than those. A Toyota/Lexus engineer said at a SEMA vendor event that these are designed for a 33” tire. Misread the tire size -- yeah that size would be pushing the limits of what fits.
Not sure if a 34” tire will fit without rubbing.
You might try searching posts for someone else who may be running 34”s.
Tirerack seems to only list LT tires in their Land Cruiser configurator. Not sure when and why 80 psi became the primary recommendation on a 5000lb vehicle. There's a reason the stock tire is 35 psi
Ah I misread that as 60 instead of 65. Yeah, 34" is pushing it.
80 PSI is what your dentist would like you to inflate your tires to.
Rattle the fillings out of your teeth. Generate more business for them!
BFG KO2 stock size 265/60 R20
after and before.
A local dealer installed 275/65/20 Falkens on their LC and I test drove it. I think that size will be fine.
Reactions: CB3
