22 MPG!
Esquire
409
571
Omaha, NE
2024 Toyota Land Cruiser Premium - Black / Black; 2016 Porsche 911 - 991.1 Carrera Base - Black / Black; 2022 Toyota 4Runner Limited - Black / Redwood
Just returned from a little 200 mile journey.
Avg 22 mpg.
Impressive for a 6.000 lb truck.
Did you keep it to 55mph the whole trip?
Actually I was on avg between 65 - 75mph the entire trip. 6 towns where I had to slow / stop. The rest interstate at 75mph.
I wish I knew..... perhaps I should change my driving style
For turbo engine the time you spent driving within the turbo zone the gas efficiency will disproportionally drop off the cliff. It is sort like afterburner.
Minimize the time having turbo turned on will significantly improve your efficiency, though some will actually describe that as “hyper-miling”
I kinda already know this after watching how all the owners of Sequoia complained for years. They give you hypermiling efficiency not realistic one. But you pay for the gas so it is up to you.
This is something Toyota can improve by just change that hybrid battery into a larger lithium version but they decided not to do so so that’s it.
I am only getting a little over 18 but it is mostly in city driving. I have taken her on a 300 mile road trip but did not see any improvement. May help if I kept my foot out of it. LOL
Did a round trip Saturday NJ to Syracuse, I averaged 22.1 mixed driving.
Yes. 20" factory wheels/tires.
I had the stock 20" tires for the first 1000 miles, and averaged around 23 mpg. Switched to 265/60 R20 KO2's and now I'm at just over 20 mpg. Big, tough, heavy tires do make a difference. Lower mpg, but where I drive here in Wyoming, rock punctures are a common problem, so I'll take the hit in mileage to get the tougher tire.
Are those LT rated tires? I'm thinking of staying away from E rated for that reason. I'm a bit torn though.
Yes, the full description for the tires: BF Goodrich All Terrain T/A KO2 LT265 /60 R20 121S E1 RBL. With the E-rating, BFG recommends higher pressure then the OEMs for the LC 250, around 40 psi. I went with 38 psi, and it seems to be fine. Perhaps an even higher pressure than 38 would improve mpg a bit, at the expense of a rougher ride.
How? I'm averaging 15mpg so far.....
Exactly. Even driving gently and staying 65-75 mph I got about 17.5 mpg with OEM wheels and now with some 35's I am getting 15 mpg. On a recent trip from the Bay Area to Boise going 85-90 mph I got 11.5-12.5 mpg. No idea how this car is rated for or anyone can get north of 20 mpg. I did not buy this for the hybrid engine or efficiency, but it is a pig.
