Ewwww, I do not like it here or there…I do not like it anywhere.
LC/GX exteriors are more visually appealing to me and their interiors seem more refined…but to each their own!
9.5 rear diff on TH 4R is nice and better than the LC.
and so 9 trim levels?!? wow.
makes me think we’ll see at least one additional LC trim after the FE.
let’s not forget this one that was spotted.
perhaps a TH LC will get the bigger diff?
This all really begs the question as to what, other than styling, is the difference between the LC and the 4Runner?Short article with a quick comparison of 4Runner and LC
How the 2025 Toyota 4Runner compares to Land Cruiser and the old 4Runner - Autoblog
The 2025 Toyota 4Runner looks like it'll be a clear improvement to its predecessor. Though looking at the specs, it may pose a problem for the Land Cruiserwww.autoblog.com
My husband bought one of the new 2024s, it is tight. OK for my littles, but a little cuddly for adults.This pic makes the back seat look tight. But it also looks like the front seat is crazy far back. This makes no sense since it's longer than the 5th Gen. I expect that back seat leg room will be fine. I'm 6'2" and in my 2010 there is plenty of room behind my seat, just can't see that not being true in the 6th Gen.View attachment 1324
Specs | 2025 Toyota 4Runner I-Force Max | 2024 Toyota Land Cruiser |
Engine | Turbocharged 2.4-Liter Four-Cylinder Hybrid | Turbocharged 2.4-Liter Four-Cylinder Hybrid |
Transmission | 8-Speed Automatic | 8-Speed Automatic |
Drivetrain | Part-Time or Full-Time 4WD With Two-Speed Transfer Case | Part-Time or Full-Time 4WD With Two-Speed Transfer Case |
Power | 326 HP / 465 lb-ft | 326 HP / 465 lb-ft |
Towing | 6,000 Pounds | 6,000 Pounds |
Wheelbase | 112.2 Inches | 112.2 Inches |
Overall Length | 194.9 Inches | 193.8 Inches |
Overall Width | 77.8 Inches | 77.9 Inches |
Overall Height | 70.8 Inches | 76.1 Inches |
Ground Clearance | 9.2 Inches | 8.0 Inches |
You are correct about the 4Runner's drivetrain. It's definitely confusing since there are so many 4Runner trim levels to compare apples to apples.@Dragoon - isn’t that article incorrect on drivetrain specs?
LC is only full time 4WD
4R has a couple options depending on the model. 2WD, part time 4WD & full time 4WD
also worth noting LC has center diff lock and rear locker.
4R has rear locker on some trims (confirmed on TH & Pro) and looks like center diff on others (like Limited). so far haven’t seen 4R with both center and rear locker like LC
