What’s included at delivery.
That looks like an aftermarket part...
Can also get knock offs on Amazon.
Just received my LC Underground from South Coast Toyota and had all covers and mats included .Haven’t figured out where my toolkit is yet though.Congrats regardless !
Congratulations looks identical to mine LC LC with premium package and underground. Can I confirm you also go the small hitch guard and the hitch slider?
That underground color is pretty BA…I have a FE meteor shower…originally was going to do underground LC w/premium…oh, man…
Bumper cover, half hitch cover, first aid kit.
Does anyone know the receiver size.... 2", 2.5" or 3". I found a really cheap Aluminum soft shackle insert on Amazon and want to make sure it's the correct size.
I've got an idea that I may be able to fashion a plate that's welded onto the insert, that will eliminate the ugly cover completely but be more appealing when installed.
It is a 2 inch receiver. It is thicker than most on the sides so you need an extra long bolt. I found a bolt for a 3 1/2 inch receiver was adequate for this one.
Sorry, FE.
Thanks. The dealer told me the LC, LC does not get the bumper cover which is only for the FE. The first aid kit and small hitch cover is also included. Interesting enough mine also had the hitch pin (??)
Pics if anyone needs them.
I took everything off yesterday and have started work with a friend on a new solution to give it a diaper change. Decided on a 3 piece design to keep cost down and not have to glue and weld and sand the 3d prints, because I dont have a 15" bed. Needing to squeeze it in on my bambu x1c. Pic for attention. My initial design will retain use of the half cover. I wanted something I could pull off real quick if I needed to grab a trailer in a hurry.
What is the bumper cover?
My LC trim came with the big hitch cover and covers the entire hitch. The smaller cover that covers the top half while in use, a first aid kit, and I guess some tools.
its a cover more of a flap that lays over your bumper to keep from scratching when unloading items.
It also attaches up higher on each side, in case cargo shifts while driving, to prevent the cargo from damaging the inside of the rear door.
