Im interested in the 2.5" lift from Westscott. Anyone have experience with this kit or other recommended kits? Thanks in advance.
Would you mind posting a pic of the side straight on like in the pic below? The pic below is from the Westcott install video, but I've seen other LCs with this lift that ended up with reverse rake.I had mine installed last week. No difference in ride, however in terms of lift I got the full 1" in the rear but only just over 1.5" up front. Waiting to hear back from Westcott to see if that's normal.
Yes that looks great. Curious did you consider the Toytec front leveling kit? If you did, would you mind sharing why you went with the Westcott?View attachment 11020
Front is 37" from fender to ground, rear is 37.75". Still a bit of rake to it. On stock 20s.
Are those 35's alsoInstalled them on my LC 250, no change to ride quality, tiny rake. Ordered a suspension package from KING.
Any issues with the tires rubbing? Other than the lift, did you need to make any other changes to accomodate the 35s? Maybe you could post a pic from the front showing the poke? Thanks for sharing your build!Had the Westcott pre-collar lift installed about 3 weeks ago now along with 17" wheels and 35x12.5 tires.
Floor to fender
- Rear = 39.5"
- Front = 39"
So there's still a slight rake...
I ordered westcott lift, but the lift company told me to be careful as people report a "pogo stick" kinda ride with this kinda lift?? Anyone feel like this lift has worsened the ride quality? Thanks
