Total Chaos / King Coilover Kit
cmpugh7
41
43
VA
2024 Land Cruiser - 2024 Land Rover Defender 110
Installed Total Chaos PART #LC250-24-25-K2A yesterday.
Only put a few miles on it because I still need to get an alignment, but initial impression is ride is stiffer/smoother than the Dobinson kit that I had on it. I am going wheeling next Tuesday so should be able to report back real world off-road experience on the same trails I ran with the Dobinson kit. I'll have my Westcott sliders installed as well, so I'll be choosing some harder lines.
Install was very straight forward, and took me about 5 hours start to finish. The toughest part was removing the upper control arm through bolt on the driver side. Took some pry bar manipulation, but ultimately was pretty easy by coaxing it from the engine bay.
Some things to note for those wanting the kit. It was nearly impossible to find how much initial pre-load was on the coilovers straight from King... In doing some calculation and measuring off the vehicle, I was able to determine it would gain about 1.5" over stock. I turned the collar 3 full turns prior to install, which yielded exactly 2.1" (5 turns = 1")... which brought be down by .4" and was perfect to achieve a little more rake. It would be pretty easy to gain nearly 3" in the front if desired... I was only down roughly 6 threads at 2+/-".
I would encourage doing your homework/calculations and adjust prior to install, otherwise you will be removing the tire, removing the upper control arm knuckle bolt to get it out of the way of the remote reservoir hose, or removing the coil all together.
In the rear I'm still running Dobinson 2" coils w/ .5" spacer. With all the weight it yields me about 1.5" of lift.
Sorry I didn't get better pictures... I'm terrible about doing that during install.
