Yes, that's correct. You know, I have just over 300 miles on the vehicle, and I've probably driven 10 on the new tires. I don't know if I can tell. It seems fine. ¯\(ツ)
Curious on your thoughts after you've had more time to drive it: 1) are the road manners more harsh with a load E tire and 2) is it more sluggish, and assume less MPG. Hard to baseline those comparisons with only 300 miles pre new tires, but curious nevertheless.
I like those, and the offset would push it out a bit for a better stance. I've also been seeing the wheels below on '24 Tacos, but can't find a part number for them. They're 18" and 6-bolt pattern, but I'd like to confirm 6x139.7 and what offset is.View attachment 1852
Don’t have a part number for you yet, but TIS says they’re a 20mm offset.
Anyone know who owns this vehicle?
I have a spare set of the exact same TRD Pro wheels and tires, wanted to know if it rubbed at full lock/stuff?
Anxious to hear the answer to your question as well! I have seen that same vehicle in posts and photos elsewhere. Considering the exact wheel setup. Looks just right!
I'm just gonna send it. I have the full set (including a spare!) ready to go in my garage for whenever my LC gets here.
Have you tried asking @Dragoon ? Since he was the one who posted the picture.
I did, he found the photos elsewhere and it wasnt his vehicle.
Thanks! 20 offset looks like the maximum poke I'd want, from people's pictures, but I'll have to do a test fit.
Note that offset is relative to the wheel width, not the vehicle. A +20 offset in an 7.5 inch wheel looks VERY different to a +20 offset in a 9 inch wheel.
I will say even with load. Range SL it rides rougher than stock Michelins , noise is not an issue , but ride is harsher . I will check air pressure and see if they are too high
This was the reason I went with the Falken Rubitrek which is a milder AT tire than the Wildpeaks. I hope they eventually workout for you. Let us know what PSI they were running at.
I ordered icon wheels recon slx in 18x9+40 and 285/70r18 tires today, should be here on Tuesday. Outside of Ben Calhoon/dissent Offroad, I have not seen anything in this size without spacer/lift. fingers crossed they work out… I will post here once installed with details.
Looking forward to seeing the results!
