Really looks sweet, looking to do the same tire and wheel combo. Do you have a side view?Method 703 Gloss Titanium 17x8.5 +0
Nitto Ridge Grappler 285/70r17
View attachment 12530View attachment 12531
That size will not fit in the spare spot. Need to go with smaller tire or wait for a rear swing mount which Iβm doing.And the spare?
Thanks. Yes, we followedThis with the Toyo leveling kit you used is identical setup to that video on how to fit 35"on. And I really like this look. No offset and looks solid.
thanks. Yes, copied the YouTube video. Dealer thought we may need to remove the crush bracket but ended up not removing it. No rubbing but itβs real close. I may end up removing it.This with the Toyo leveling kit you used is identical setup to that video on how to fit 35"on. And I really like this look. No offset and looks solid.
This looks awesome! Which method wheels are these and off set.Added new tires and wheels today. Went with Toyo AT3 and 275/70/18. Method wheels.
method 707 matte black with 18mm offset. Toyo AT3 275/70/18. Basically the rounded part of the tire sticks past wheel well flare. The tread is under the wheel well still.This looks awesome! Which method wheels are these and off set.
Great thank you! Is it on factory suspension?method 707 matte black with 18mm offset. Toyo AT3 275/70/18. Basically the rounded part of the tire sticks past wheel well flare. The tread is under the wheel well still.
YesGreat thank you! Is it on factory suspension?
