I cannot get the tire pressure light to turn off. All 4 tires have proper pressure. And I can’t reset it with an OBD. Has anyone else run into this?
I mean you don’t want to put the spare on, only to discover that it is also flat .Geez, an active tire pressure monitor on the spare tire. And it is difficult to get to it without dropping the whole tire. Pretty dumb design. Wish I could just cut off sensor on the spare.
You can also input a tire pressure. I checked mine and it was set to 33. No need to relearn anything.Go to the settings menu on your driver dashboard screen, look for the Vehicle Settings, then TPWS, you'll need to tell it to relearn the current pressure setting, takes 3-5 minutes.
Which setting in TPWS resets the pressure?Go to the settings menu on your driver dashboard screen, look for the Vehicle Settings, then TPWS, you'll need to tell it to relearn the current pressure setting, takes 3-5 minutes.
