Speedometer is way off
REMC
12
3
Colombia
Prado 250 diesel
I felt like my speed was slower than what the car displayed, so have been comparing to Waze. At low speeds there is around 3 mph (5 Km/h) diference, at 70 mph is around 6 mph (10 Km/h), what seems like a lot to me.
Has anybody checked in a more "accurate " way?
Mine reads Km/h, no mods so far.
You are going slower and the mpg is reporting higher than actual too. The 4Runner do the same thing. When I swapped my 265s for 285s on my 4Runner, the speedo was corrected. I tell myself that they designed it this way on purpose because they know many of us will be up-sizing to 285s.
Mine is correct based on those signs that display your speed.
GPS based speed is also not accurate unless the road is completely flat.
I replaced the stock tires with 275/65/20 Pirellie Scorpion's which are theoretically 1" larger in diameter. My speedo and my Waze/iphone GPS were spot on before, but now my truck reads 1-2 mph slower than indicated on GPS.
Regarding Takara's comment on GPS accuracy .. the wisdom of the crowds (i.e. the Gemini AI search tool) says this -
  • Good for most situations:
    Under normal conditions, the GPS speed reading on an iPhone will be very close to your actual speed.
  • Factors affecting accuracy:
    • Signal strength: Poor GPS signal can lead to less accurate speed readings.
    • Weather: Heavy rain or dense clouds can interfere with GPS signals.
    • Environment: Buildings, tunnels, and dense foliage can block GPS signals.
    • Road curves: GPS might not perfectly capture sharp turns, leading to slight speed discrepancies on winding roads.
I hope you are joking. Or do you really not understand how to calculate a tire height?
Sorry but 285 is not the height of the tire. It is the width in mm’s. The second number, commonly 65 or 70 is the aspect ratio which is actually a percentage of the tire width that designates the height of the sidewall from outer rim to outer tire. The third number is the rim diameter in inches. 285/70/18. That is how I always looked at tire sizes. How about you.
tire size designation, like "P215/65R15", indicates the tire's width (215mm), aspect ratio (65%), construction type (R for radial), and the rim diameter (15 inches) that the tire fits on, where the first set of numbers represent the width, the second set the aspect ratio, the letter indicates construction, and the last number is the rim diameter; essentially, it tells you the key dimensions of the tire to ensure proper fit on your vehicle.
Is a 265/70R18 the same height as a 285/70R18? No. The width has a direct relationship to the height. Therefore, changing the width does change the speedo.
The tire width has no direct impact on tire height or diameter. The aspect ratio will ultimately determine diameter. You’re digging a deeper hole there bub.
You have enlightened me on why people are putting wide tires on a 4wd, some of them think 285 is the tire height.
Okay, lets do the math. Lets assume a 70 aspect ratio is a constant.
A 265/70R18 is 32.6 inches tall.
A 285/70R18 is 33.7 inches tall.
They both have a 70% aspect ratio.
The only number to change is the width.
The 285 is 3.38% taller than a 265.
Now back to original purpose of this thread.
If the speedo reads 70mph on 265s and the GPS says your speed is 67.5mph, that is a 3.70% error. Now switch to 285s and the speedo reads 70 mph, the vehicle is 69.8 mph.
You can go to tiresize.com and check my math. It is pretty close I am sure.
I did my checking on a straight line, the weather wasn't bad, 9% is a big error. I've checked other cars before, 2-3% diference is pretty common.
You can’t know whether 265 to 285 changes the height unless you also know the sidewall proportion of both tires.
The is the aspect ratio of 70%. It is the same on both as noted above.
Then they aren’t the same diameter.
Here is a website that does the calculation for you, including speedometer inaccuracy. Pick the “tire comparison” tab.
Exactly.
Here is the math for a 285/70R18:
Determine the sidewall height by converting the width from mm to inches:
Use 285mm divide by 25.4 mm/inch = 11.22 inches
Then multiply by the aspect ratio of 70%:
0.70x11.22 inches = 7.85 inches
There are 2 sections of sidewall -
2x7.85 = 15.7 inches
Total height is 2 sidewalls plus the rim diameter-
15.7 inches + 18 inches = 33.7 inches.
Therefore a 285/70R18 is 33.7 inches tall and 11.2 inches wide.
I think you think you are schooling us here but 285 is a width measurement only.
