SLEE Under Hood Compressor kit concern
Area 51
๐Ÿ“› Founding Member
Dec 12, 2024
505
376
NorCal
2025 Land Cruiser, Jeep TJ built.
Looking at the two finned for cooling modules, i am concerned about killing what Toyota clearly intended for extra vertical convection cooling.
Don't know what the modules do yet but they are both going to get significantly hotter with the SLEE kit mounting and relocation.
Rethinking the compressor plan.
๐Ÿช ๐Ÿช ๐Ÿช ๐Ÿช ๐Ÿช
Another good way to go for flats and just getting going quickly with no spare change is a Power Tank. going to carry one of these for a while with an ARB fix kit, this has worked well in the past.
Power Tanks are great...... except for the space they take up. I used one for years to power my train horns.
Not far form me will try to go see them tomorrow.
This looks good as a short term fix,.
I'd find out where you can get the tank refilled, before I purchased.......... I had an issue getting some tanks filled.
We were concerned with the heat build-up as well. That is why we opted with the compressor on top of the ECU vs. underneath it.
We ran temperature test with the bracket installed alone and then with an ARB on the mount and running with the air outlet open so it ran continuously. This was on a day where the ambient temp was around 60 degrees. We will repeat once our daytime temps go up again. We had one probe on the ECU and a 2nd on the Transmission ECU. Those are the two components that are relocated. All this was done with the engine running and hood closed.
Below is the graph of the data. As one expects that temp went up since the motor is running however there was no drastic spike of the temperatures on the ECU and Transmission ECU with the ARB compressor running for a full 30 minutes.
We will do more testing at higher ambient temperatures, but we are not concerned with it.
Thx Chris. Surely a good start.
My concern is going through a place like Needles Ca in the afternoon at a high ambient temp, let's say 130f and then seeing what the ECU case temp is. anything fails on either of those two modules would be a warranty violation if the remounting was seen, and get very expensive quickly. The vertical convection cooling of course dies when the module is flat, not sure how much air flow is changed. Thx for your attention and looking forward to good news.
I am not sure how much Toyota is relying on airflow to cool the ECU. Attached is a photo of the GX550 ECU location. Way more restrictive, closer to the radiator and a lot of airflow blocked. When we drove the vehicle with the bracket installed there was little change in temperature on the ECU with or without the bracket installed.
One thing to remember if you are driving and have the compressor on, it is most likely for lockers (if we ever get ARB"S for it) and then the compressor just runs occasionally. Airing up is probably when it runs the most and we would also recommend opening the hood when doing so. Even in this and other applications.
Also when the new ARB Brushless compressor is available the heat generation from the compressor will be greatly reduced.
Once summer hits we will do more testing with temp measurements under the hood vs. on the ECU to get a better base line, but I am pretty sure Toyota probably designed that ECU to take way higher temps than what we would ever see,
