Roof Rail removal process?
BigMF
221
280
Nashville, TN
2024 Land Cruiser Premium, 2011 Lexus LX570 (Retired)
Can anyone post a quick set of tips on removing the OEM roof rails? I'm particularly interested in the initial steps on how to get the plastic covers off without breaking anything. I assume that once you get the covers off the rest is relatively intuitive.
I also assume that the steps are generally "Pop them off", however, it would be nice to know if you should start prying them off in a particular spot around the cover to avoid breaking any clips.
Here you go friend
  • dripmoldremoval.pdf
  • roofrackremoval.pdf
Here you go friend
Awesome! Thank you sir!
If a moderator/admin is reading this, it would be nice to have a section where these kinds of documents can be stored/accessed as people find them.
Have you found the proper delete kit after removing it? I’m struggling to.
Sorry, can’t help you there. I installed a Prinsu so no need for the delete kit.
Here you go friend
These were exactly what I needed. Had the rails off in about 5 minutes. Really helps knowing where to pry/pull to make sure you don’t break any of the clips. Thanks again!
Actually, the part numbers appear to be in those linked PDFs as well
