Anyone else repeatedly getting a rear seat alert on the Toyota app? I have nothing on the rear seats, but on an at least daily basis get an rear seat alert message on my app.
Rear seat reminder function
As the first reminder so as not to forget luggage, etc. in the rear seat, when the power switch is turned off after any of the following conditions are met, a buzzer will sound and a message will be displayed on the multi-information display for approximately 6 seconds.
Also, as the second reminder, when the doors are locked, a buzzer will sound and the emergency flashers will flash for a few seconds, and a message will be displayed on the multi-information display.
â—ŹThe hybrid system is started within approximately 10 minutes after opening and closing a rear door.
â—ŹA rear door has been opened and closed after the hybrid system was started.
The second reminder will not be activated if a rear door was opened before the doors are locked.
However, if a rear door is opened and then closed within approximately 2 seconds, the rear seat reminder function may not operate.
The rear seat reminder function determines that luggage, etc. has been placed in a rear seat based on opening and closing of a rear door. Therefore, depending on the situation, the rear seat reminder function may not operate and you may still forget luggage, etc. in the rear seat, or it may operate unnecessarily.
Mine shows the rear seat icon Every Single Time I crank the LC then it goes away. I don’t know why it does that. Is your doing this or is it only after you shut the engine off?Anyone else repeatedly getting a rear seat alert on the Toyota app? I have nothing on the rear seats, but on an at least daily basis get a rear seat alert message on my app.
In the dashboard is where the rear seat icon keeps coming on every time I crank my LC!Mine shows the rear seat icon Every Single Time I crank the LC then it goes away. I don’t know why it does that. Is your doing this or is it only after you shut the engine off?
