This is what is stock on a non roof rail 1958. I used simple sealing washers and silicon when I installed my towers. You will note the white plastic tubes that stand proud of the roof gutter. I had to slightly enlarge the sealing washer hole to fit over them, hence a little silicone as well. It's a pretty silly system as the plastic piece in the first picture simply caps the rubber gutter rail inserts. I left the rubber insert out between the two towers. I may glue is back, I but I would need to trim it a little bit first. The third picture shows the attached tower base - you can see the stainless sealing washers underneath the base. My inclination is to simplify a plate over the rubber ends that one simply bolts through rather than the bolted on wire clip and the plastic snap on cover that attaches to it.
Thank you both for the detailed responses.
