Nitto Ridge Grapplers on stock 1958?
juicyjonathan
๐Ÿ“› Founding Member
Oct 15, 2024
5
0
St. Louis
Land Cruiser
I just put a deposit down on a 2025 1958 fresh off the boat from Japan. I know I will be putting Ridge Grapplers on the stock 1958 wheels, but which size can I do without any modifications? 285, 275, 265?
Is one of them "ideal" for the 1958?
Pictures are appreciated!
Mine came with 265/65r18 Ridge Grapplers. Could certainly go a little bigger.
Right, but bigger how? Like what's the difference between a 275/65/R18 and a LT275/70/R18? What would be the benefits or disadvantages?
Is that the size used in the Toyota distributor add on? Do you know if the wheel size was also increased or if that accessory only swapped out the tires?
