Method +35 Photo Request
@uraniumrich and @LcAz did you go with the Method 106.25 to 95.25mm Hub Rings? I'm looking to order the wheel/tire combo thru an online vendor and by default they recommend/offer Gorilla Automotive 106 to 95.1mm Hub Rings. Not sure if I should go with the Gorilla's, order the Method's or order a custom set that's the exact difference between the 703's and the LC Hub (106.25 to 95).
The hub rings must be exactly sized to be useful. I did not find a source for the 106.25 to 95.1 mm hub rings that are needed. However, the Method wheels are lug-centric, not hub-centric. In other words, while I would've like to have the hub rings, they are unnecessary to run the wheels. You can have the rings made to order, but that's a bit more expensive.
Agreed, itโ€™s not that the wheel manufacturers somehow forgot to make hub rings that are required for a correct fitment. They will offer lug nuts that center the wheels though.
Method 705 18x8.5 +35 (a few lbs lighter than the 703)
Wrangler Duratrac 285/75R17
No lift
Just a liiitle poke. Looks perfect to me.
I'm considering going with a set of Method 703 +35 offset wheels. I'm debating between those and something with a +40 or +45mm offset. If you have a set of Method wheels with a +35 offset and have a tire close in size to a 285/70R17 (11" wide), can you post photos of the amount of poke you're getting? (I'm looking to get just a slight amount of sidewall poke, without sending stripes down the side of the truck). Thanks!
