Would look good but lose the iforce max badge. Too much badge clutter with both.I bought this a long time ago and tried it on my new LC, what do you think? Organic or lame? I have it on with magnets but im not sure if i should make it permanent.
Where did you get these!! They are perfect!!!A little extra storage
It’s in that post. I had to re-do the application of the double stick tape because I didn’t prep the surface. Took the opportunity to use some heavier-duty Velcro I had laying around. Voila, now it holds well. .Where did you get these!! They are perfect!!!
I think it looks good but the I-Force looks like hot garbage. That was the first thing I took off!I bought this a long time ago and tried it on my new LC, what do you think? Organic or lame? I have it on with magnets but im not sure if i should make it permanent.
I just “Toyota” lit up on mine…. Where did you get the “Land Cruiser ” one????Just came in from Japan
Where did you get those?Installed my new puddle lamps on the doors and it looks great! The install could not have been easier. Pop out the old lamp assembly, disconnect the wire, plug in the new lamp assembly, pop in the new lamps. Link to Land Cruiser Lamp.
Yep purchased them from stickerfab last night. Getting rid of my TRD ones
Looks awesome! Now I want to get these instead of my “Toyota” onesJust came in from Japan
Amazon has a lot of covers for essentially all plastic part of cabin in carbon fiber print. You might also check out these. I would buy it if it is not carbon fiber but more natural texture like dark wood.Another option for more storage. Fresh off the plane from China. My first impression: it’s ok. Could be a little darker but it fits… $55 well spent? Maybe.
View attachment 13584View attachment 13585View attachment 13586
The only problem with those is the profile is generally rather thick + the 3M tape - so for something like buttons, they would look really recessed. I had this same experience with my previous car. As much as I hate to say it, a vinyl wrap is probably your best bet.Amazon has a lot of covers for essentially all plastic part of cabin in carbon fiber print. You might also check out these. I would buy it if it is not carbon fiber but more natural texture like dark wood.
I agree, but not everything is next to buttons. Plus vinyl is general not working too well neither with curves surfaces. (the type you get on Amazon is likely not last for heat and UV too). It’s a choice between pros and consThe only problem with those is the profile is generally rather thick + the 3M tape - so for something like buttons, they would look really recessed. I had this same experience with my previous car. As much as I hate to say it, a vinyl wrap is probably your best bet.
If someone can get a PNG, JPG, SVG, DXF, GIF or a BMP in exact dimensions for whatever they are trying to protect/wrap, I'm happy to cut for people.
Sweet! What’s the part # & where did you order? TIA
What happened that you needed cust service? Does it come with just 2 illuminated front pieces?They have amazing customer service!Toyota Scuff Illumination for Landcruiser 250 | Genuine Japanese Car Parts
Easy Cars Tokyoeasycars.jp
