Would you recommend it - thinking of ordering it
Sure, It's small but I like it. My wallet typically ends up in there for long trips.
Makes the most sense if you already have one of the coolbox storage trays as this space would otherwise be wasted. However, if you don't have the tray and are into super tall drinks then I'd avoid it.
anyone try these yet? A couple different style options on Amazon searching for "lc250 splash"
Amazon.com
Got the Carista Evo today and customized the following hidden settings on the LC FE.
  • got rid of that annoying driver seatbelt chime
  • trunk lid button lower dash from long push to short push
  • signal chime from medium to low
  • long push on remote to lower all the windows at once including the sunroof
Upgraded the dash speakers with Infinity Reference speakers. With the Beat Sonic amp, the so called JBL Premium sound system is sounding better and better. It's about 5mm short on one side.
Adapter mount from Etsy worked great.
Are these the adapters you used? And I assume these are the REF307F speakers?
Here is the list for my 2025 Underground LC.
Yes' same seller. My speakers were the 3032CF' supposedly the same speakers as the 307F. I think one replaced the other. I left the center dash speaker alone. Couldn't find a speaker that would fit with the right depth. I added foam around the front door speakers and with the sound deadening and the Beat Sonic sounds great. Doors sound solid now when shut closed. I think I'm done now and will leave the rest of the rear speakers and woofer alone.
As far as the Etsy adapters, the left side fit perfectly. The right side' I had to drill a small hole on the right of the adapter for it to fit. Without that, the grille cover would not snap in place. Let me know if you want a pic of that section.
You able to share pics of these on?
Made the same essential changes.
I'm back in Japan and tried ordering this half ladder, but they were out and don't expect it in until sometime early next year (bummer). No drilling, bolt on installation. Does not affect rear window and rear lid operation.
I did order this Brake Hold Kit and had it delivered to my hotel. The kit will keep the brake hold function activated all the time, which I loved on my Tesla.
Amazon.com
I had this installed. One thing that took me a bit time to adjust is that the alignment for the splash guard is not that good and it affects how my door is closed. Not a bit issue but just the fact that you can easily differentiate from the quality that it is not a factory part.
View attachment 21116View attachment 21117View attachment 21119View attachment 21120
Is there any compromise for the ladder? I was debating whether I want to install this or do a bigger mod to install aftermarket bumper with wheel mount.
According to the retailer, there's no drilling, it is bolt on installation with double sided tape for added security. Backing also has soft foam for added protection on painted surfaces. You can still lift the rear window and open the rear lid without any obstruction. They would have delivered to my hotel if it was in stock. This would have been perfect for my needs.
I would do the bigger mod with a wheel mount.
I can’t see the ladder. 😜
I would love that brake hold kit. Do you know if the vendor will ship to the US?
Yes they do. The item description will specify what countries they can ship to, which appears to be most of their stuff, even large items. I've ordered before and shipped to California with no issues.
I've installed the Beat Sonic amp, so the brake hold kit is even easier (watch install video on link).
Thanks! I looked at the video and it appears to be a pretty straightforward install. I'm adding that to my wishlist.
