Light Bar and Ditch lights Baja Designs Wiring help Please (Pics Please)
Bappy
๐Ÿ“› Founding Member
Aug 6, 2024
117
105
Arizona
2024 Toyota Landcruiser
Guys I have a 40" Baja Designs Light bar and Baja Designs Ditch lights. I am very confident in electrical and wiring. But I am looking for pictures or details on how you have wired. With the battery in the back just interested in Where you ran wiring and how your set up looks. Please post pics
Thanks in advance Bappy
There is a member who posted a diagram on he wired his lights. Others have used this YouTube video, which details how to get power from front engine bay.
I sent you a PM
Appreciate you EOD, I got it and already ordered what you sent. I have used the Circuit Breaker on my side by side and used a separate fuse panel. I like the buss bar and will use it. Also thank you for the advice on disconnecting the Neg Cable.
I sent you a PM
One more thing, what material did you use to create the longer attachment to the battery post and also what did you use to make the bracket to hold the Buss bar and Circuit breaker
I used a piece of scrap stainless steel for the buss bar extension and a scrap piece of an old alum road sign bent into a "L" shape for the bracket to hold the C/B and buss bar.
How thick is the aluminum? any chance you have a drawing of the relay bracket?
I don't have drawings of any of the brackets I've made. I use cardboard and tape to make a template and discard the template when finished.
