Let's see the Poke
KWLC250
30
9
Key West, FL
2025 Toyota Land Cruiser
Can we start a thread with photos of your rig, the poke your setup has and the details/spec of wheels and tires? Seems to be a pretty common question on all the forums, FB groups, etc. I know I've been scouring all of them for good photos of how different size tire/wheel combos sit in (or out) of the wheel well.
Please include Wheel Dimensions (including diameter, width and offset), Tire Size with Brand/Model, whether you've got a lift/level kit and your LC trim.
I'll kick it off... This isn't my truck but a posting I found in a FB Group
Wheels: Method Race Wheels 318s
Dimensions: 18" x 8.5" +40mm
Tires: 275/70/R18 Toyo Open Country ATIII
Trim: LC (Base)
Factory 20"wheels
Michelin X-Ice snow tires in 275/60R20
Not the best photos but it's what I have from when they were on the LC
Front and back
Tacoma TRD wheels 18" x 8" 45 offset PTR56-35242-F1
Goodyear Wrangler Duratrac RT tires in 265/70R18 SL
Stock suspension
The stock mud flaps are kind of marginal on these, I'll be installing something wider soon.
**Added pics of hoe far outside wheel well.
2.5 Inch lift
Toyota Premium wheels
275/70/18 Falkin Wild Peak at4w
Tires stick out a little - maybe 1.5 inch? I didnt measure but as you can see it sticks out about 1 tread notch outside the rear wheel well.
No lift. 285 70/17 wildpeaks, method wheel, not sure which but it’s zero offset… very aggressive stance with a good bit of poke. This wasn’t really my plan but I had just put these on my Tacoma and didn’t want to buy all new wheels and tires… kinda broke the bank on the purchase of the LC… so. Yea.
Updated: RokBlokz standard mudflaps on Tacoma TRD wheels 18" x 8" 45 offset PTR56-35242-F1 & Goodyear Wrangler Duratrac RT tires in 265/70R18 SL. Looks like perfect coverage, especially on the front.
Raceline Krank
17x8.5+18m
Tires
Toyota RT Trail 285-70-17
C-load
ORW 1½ Front Level Lift
Wheels: Method Race Wheels 703
Dimensions: 17" x 8.5" +35mm
Tires: 285/70/R17 Toyo Open Country ATIII
Trim: LC (Base)
Need to find a solution for the spare tire.
