LC250 Skid Plate
BadKarma
14
14
Indiana
2025 Land Cruiser LC
What is the consensus on skid plates and the radiator support mounting option? I’ve seen the threads for available options, but should I seek out a solution that uses the tow point location instead of the radiator support location, or is it not something to be concerned about?
Am concerned a bit about this myself, but do not anticipate tackling rocks, only sagebrush. Hope it is sufficient for that?
Thanks. I saw that list, but should the options that install with the radiator support be avoided?
If it's me buying an aftermarket part, it has to be better than the OEM for my intended purpose. So yes, I would avoid them.
I would also look at ones that provide easy oil change access so whoever changes the oil doesn't have to drop the entire skid plate every time.
I was concerned about the radiator support mounting so I bought the victory 4x4 skids. They mount to the recovery points, not the radiator support. Very happy with quality/finish/delivery timing.
That’s probably what I’m going to end up doing as well
