KO3's!!!
I still might buy a set of these for my 2nd set of wheels for fall hunting and winter duty.
It would be nice to see a head to head test of these against the Falken Wildpeak AT4W, and Toyo Open Country AT3.
I have been running the KO2 on my truck and the Toyo AT3 on my landcruiser for several years. I traded in my truck for the new landcruiser and I put on new AT3 and I still have my old landcruiser with AT3 on still. I prefer them over the KO2 but I haven't tried the new KO3. They are both fairly close and equivalent on all parameters. I think the AT3 are better in the snow and slight edge in the rain. I run a lot in the snow so went with those.
Ok so got the KO3's in the stock size 265/70/18. Now I was not 100% that I needed an LT tire. But this tire has so many appealing characteristics in terms of it's development, for sure I needed a snowflake rated off-road tire and at least for now it was what I wanted to experience. The other aspect of it even though I figured out how to get along better with the stock tires, I did not like what I perceived to be the roll from the weak sidewall. So now I am not a tire guy so the words that I am using are likely incorrect but this is my perception.
These were installed at the dealer and once again inflated in the high 40s psi as I when I took delivery of the vehicle. It must be their thing. What I can say right off is that roll that I was experienced with the stock tires was gone, so at least for now that aspect of picking the KO3's I regard as a success. Also the steering response IMO was excellent. And even with the high PSI these were not as floaty as the stock tires were at similar pressures.
To me anyway this gives the Land Cruiser the feel that I was anticipating would be consistent with the character of this vehicle. Also IMO the off road tire is very handsome and compliments the Land Cruiser. Just my preference.
Now I wasn't sure about what to do about the PSI, however driving it home I had several occasions to experience rough railroad crossings and definitely felt that was too harsh and was not allowing the suspension to do it's thing. So that made up my mind on needed to bring down the pressure.
Got home brought it down to 40 psi and then went and retested it over the railroad tracks and now we're golden. The tires are working with the suspension to dampen beautifully. After that I drove into the adjacent subdivision which has curvy roads and round abouts and the handling is now beautiful. Great steering response, well planted. This is where I wanted it in terms of the driving characteristics.
We'll see what of hit to the mpg, but so far so good and we'll see how it goes in the winter.
When we ran KO2's on our Jeeps, we always ran them at 37psi, seemed to work the best. :) Not sure about the LC, but they are good tires.
New forum member here. I recently put on 275/70/R18 KO3's from Discount Tire. Tires inflated to 46 all-around. They look great, but so far that's about all. I have put on 68 miles, mix highway and street. I didn't expect to feel this much difference compared to stock. On street, up to 50MPH, the LC feels stiffer with increased vibration, but tolerable. At highway speeds between 70-80MPH, the entire cabin vibrates. If I go around a gradual curves, vibration seems to increase...maybe more like shuddering. I plan to return to Discount soon, but any ideas on cause, like not balanced correctly? The OEM tires were very comfortable compared to KO3's, with basically no excessive vibrations/shuddering at similar speeds, whether street or highway.
Even at 84mph for me the KO3's are smooth no vibration what so ever.
Same. Great tires so far, around 4k miles. 275/70 on stock 18 inch rims.
Not for nothing, running E load tires at 45+ PSI at highway speed over broken pavement isnโ€™t totally safe. Mainstream suspensions arenโ€™t built to compensate well against that much movement and the truck will feel all over the place. Especially so if the pavement imperfections occur on sweeping curves.
