Keep stereo on after turning engine off?
I’m not sure of the timeout. There’s gonna be one so the 12 volt battery doesn’t drain.
I changed the ACC setting so the radio stays on when turning off the vehicle, but if you open the door, the radio immediately turns off. :( I was hoping to be able to have the radio continue playing when pumping gas (or whatever), but looks like it may not work.
I just want it to play while at the Drive In Theater, without the annoying shutting off, and having to be turned back on every 20 minutes.
Agreed with everyone, however the days of unlimited radio play went away in this era of wireless key fobs. They’ve made it easy to forget that cars need to be shut down, making a timeout necessary. Wish it were an option, though.
Older hack, IDK if it'll work..........
With the engine running, foot on the brake, shift into neutral, press the button to shut the engine off, shift into park, release the brake.
After turning the ignition off and with the door open I was able to operate the audio only by just pressing the volume knob. The screen with light up black and then proceed to load up. You should then be able to utilize the audio system without the ignition on. I too enjoy having the radio on while cleaning up the car. So I just discovered this a couple hours ago. Let me know how it works out for you.
Go into the vehicle settings in the radio. There is an option to turn ACC mode off. This will allow radio to stay on when engine is turned off.
Hmm, I still can't find the ACC mode off in the radio section. Is this main display or driver gauge settings?
Yeah, I used to like that my old car used to keep playing the radio even after I opened the door. It would only turn off if I shut and locked the doors.
