JDM Mud Guards with US Fitment
StickerFab
🛒 Supporting Vendor
Jul 21, 2024
120
213
Fort Myers Florida
2024 LC
Hello,
I have a great supplier in Japan from my past life with SubiSpeed / FT Speedfactory / RallySport Direct. Was wondering how many people would be interested in pre-modified OEM parts that you don't have to cut.
Some of you may know the flaps from Japan require modification for the front ones to fit properly. I'm going to grab a set and see what I can do with them. Goal is to make nice clean cuts so you don't have to go crazy on them with a knife.
UPDATE: It worked. Photos below. I could consider a 20 dollar discount if we start a group by. That would lower my shipping costs to get these here, but there's a bit of liability with me cutting these if something goes wrong and unpackaging, disassembling / reassembling, repacking takes up a bit of my time.
I'll collect orders for a week or so and order try to forecast how many I need. (2/3/2025- 2/10/2025)
You can use the above link or add the USDM prep version to cart and use coupon code "lcforum".
Not a bad idea. I'm curious if Toyota will ever release USDM versions. The JPY is pretty low right now, so I don't think a USDM version would be any cheaper.
  • Thread starter
  • Moderator
  • #5
It's possible. 50/50 maybe? I've seen items stay JDM parts for ages that would make good candidates for US parts.
Did anyone make a template of an FE edition or can take a good photo of the front flap so I have something to start with? Thanks in advance.
Yes. I am interested.
All depends on the cost... Wouldnt spend a ridiculous amount for mud flaps.
Currently from Japan they can be sourced for $350 (plus/minus) plus tax and typically free shipping. So, somewhere in the realm of sub $400.00.
StickerFab: Not that I care what you are paying for them from your Japanese source, however, are you planning on being sub $400ish as well with the modifications performed?
bulk buying = bulk discount. I would be interested based on the pricing.
Yeah, there isnt much chance Id want to spend over $300 usd for mudflaps.
Does anyone know if the JAOS front mud guards fit ok on a USDM LC? Maybe a quick solution would be JAOS up front and JDM Toyota in the back. Interestingly the JAOS installation instructions seem to allow adjustments for outboard or inboard fitment depending on if you have installed fender guards or have wider wheels/tires.
One could always keep the original mud flaps up front as well and only change out the backs.
I bought factory set from Japan. For front, took off stock mud guards and placed over new ones to sketch exact cut lines to match. Cut out easy and really no need to file edges to perfection as the cut-out edges are not visible at all IMO. That said, would have preferred receiving pre-cut to perfection!
I would be in! I have ordered many items from sticker fab. And do not want to modify existing parts to get any add ons to fit.
