JDM LC250/LC300 18" wheels high + offset
Wow, this is great to see - they really do look amazing! I literally have a set of these in my shopping cart at Black Hawk in the 18x8.5 +30 offset, and plan to put on the same tires in the same size.
I would be very grateful if you could post a couple more pic's, ideally down the side so I could get an idea for the offset/poke. Thanks in advance!
I don't know if this has been posted before but this site is pretty useful for calculating how changes to wheel/tire specs impact how much the new combo is going to stick out, plug your values in and then take a tape measure to your current setup - Rim & Tire Size Calculator. Custom Offsets
Thanks for sending. I have been using another similar site, but it's always helpful to see the real thing for perspective.
Welp...just pulled the trigger on a set of these bad boys, for my LC in the same colour. A bit pricey, but they ticked all the boxes (size, colour, weight, offset, etc.)
Can't wait to see them live!
Meant more so the hubcentric rings, (not sure why I said spacers) so the wheels sit firmly on the hubs. I have the 18x8.5 20et Bradley Vs and had to get custom hub rings, but I didnt purchase the center caps, so not sure if they would work together or not. (They are the M14 wheels as well)
@mkg where did you order your custom hub rings from?
Finally got my 'summer' wheel setup mounted.
-Bradley V, 18x8.5, 20 et
-Yokohama AT4 G018, 275/70/18
-Also have the Westcott lift, custom hub centric rings (Next year I will have them coated black) Cartrim home Mudflaps
Looks pretty sweet!
FYI - I was going to self clear my JAOS wheels at customs, but it turned out I would have only saved $11. Total taxes and duty on my wheels was $80. Ordered through Blackhawk, they offer the option of declaring the shipment at 30% off the total value (likely their cost).
Thats nice of them to offer that. I shipped with UPS, and they are known for charging an absorbant amount on brokerage. I bought a used Beatsonic amp for $200us... they charged around $100 for all the fees. (GST, brokerage, fees etc)
