Instrument cluster mostly blank
Reidog
43
26
Shoreline, WA
2024 Landcruiser
I started my car this morning and noticed I lost most of my instrument clusters. Thought if I turned off the car and turned it back on, it would reset and come back, but it’s still blank.
Has this happened to anyone else? If so, is there a fix?
I think this is the first - I’ve not seen this problem -have you had ur LC long ?
I got it in mid July. I brought it into the dealer. They managed to get the graphics back for now but said the unit needed to be replaced. They opened up an incident with Toyota and ordered the part. They said it would take minimum 3 weeks because the car is so new. Good news is, the car still runs fine. If it goes out again, I won’t be able to turn on/off safety features and my HUD won’t work.
I was logged in my own profile, all my settings were working, just not the dash.
It happened to me about a month ago. I thought the same on the restart but it didn’t work. The car sat overnight and was fine the next morning. No problems since. You’re the first person that’s had the same experience as far as I know.
Try disconnecting the battery for several minutes and see if that brings it back. If not, then I guess it's stealership time...
This happened to me too, about 2 weeks after I bought my PC FE. Had roughly 300 miles on it and I turned it in and the dials were blank other than the engine temp on the bottom and a large digital MPH in the middle, no heads up display as well. After I left it overnight they all magically turned on again and hasn’t been a problem since (one month later).
Just happened to mine around 8k miles.
Hopefully all is well after letting it sit over night.
EDIT: let it sit for 30 mins and the gauge works again.
Is this disappearing dash display becoming a rite of passage? I'll go check in a few hours to see if it has self-healed.
Edit: Checked again 2 hours later and we are back to normal.
