Installing a DC-DC Converter (aka alternator charger or DC-DC Charger)
Since the AC is rectified into DC I am not worried about the LiFePo4 batteries, rather the electronics that convert the AC to DC. Every power station manufacturer will tell you not to plug it into a modified sine wave inverter because the modified sine wave may damage the electronics. I've got a similar Fniri unit arriving Sunday and will be checking out the inverter waveform and noise. I'd rather spend a little money on a DC to DC charger than risk destroying expensive portable power stations.
Can't take a sine wave vs square wave at the same voltage and frequency = low end cheap component min design.
Same for same a square wave is more wattage or power vs a sinusoidal wave. The square wave is al harder on power components, on and off more abruptly. Steep wave front.
Are we over thinking this issue? The latest portable power banks are designed to be plugged into standard AC wall outlets in pass through mode or to act as a UPS. How many of those outlets have pure sine wave output?
An alternator charger is certainly nice to have as another and possibly simultaneous power input. However, unless you are permanently charging the power bank through the LC, I wonder if the alternator charger is worth the expense and effort? Is it wise to add another tap off the hybrid system if not absolutely necessary? Also, keep in mind the Ecoflow alternator charger is max 800 watts which is roughly 1/3 the max charging rate of the LC inverter.
Overall, I really like the alternator chargers in general. Just raising questions.
US grid power provides a pure sine wave, unless there are distortions from equipment or other issues.
Are we overthinking it - perhaps. However when it comes to expensive equipment that isn't designed for abuse I'd rather overthink, overplan and overtest.
The loads create the problems not inherent to the grid sourced power.
There are some glitches after it crosses zero but the rest of the curve is pretty smooth.
Yeah, to this point, the total voltage swing on the Land Cruiser's outlet with no load was just a little higher than at a wall outlet. It would be interesting to see what it looks like with a load on it. Hmm maybe I'll have to go boil some water.
View attachment 24556View attachment 24557View attachment 24558
I can't guesstimate if its simple switching or a PWM type sine wave.
If you open up the sweep rate a bit and look at the top of the wave form maybe focus on opening up to see the ripple better?
Looks like filter notches.
Well here's a real horror show of UPS waveforms:
Database of UPS inverter output waveforms (updated)
The LC's form looks a lot like this Eaton model: https://www.eaton.com/gb/en-gb/skuPage.5P1550I.html
And now the question is will I actually get anything done on my Land Cruiser today or will I just go around measuring waveforms from all the UPSs and batteries in the house . . . (we have PG&E for power -- our power goes out a lot while PG&E burns down lots of stuff).
The answer is no, you've dived deep into the rabbit hole, my friend! It will take at least 24 hours to claw your way out.
From the outlet in the back, yes.
My cheap scope arrived yesterday and this morning I checked out the waveform. My scope is not close to capability or precision as your however I had almost identical results. I consider that definitive - the inverter will be fine for charging portable power stations and power other electronics.
Thank you for your answers!
I'm curious about that scope! It looks way more portable than mine!
It is pocket sized but with pretty decent features: Amazon.com
You can get it cheaper on AliExpress however I didn't want to wait 10 to 14 days for it.
Debugging stuff at home, 90% of the time I just hit the "autoset" button on mine and that's good enough, so something like this would probably do the job most of the time. I have a way fancier one at work for looking at imaging sensor timing signals and such, plus lots of more typical ones. But I got tired of having to drag some power supply or whatever to work to figure out what was going wrong.
It has been decades since I used a scope at all; I need to relearn the basics of how to make the most use of it. Yay, another project (sigh).
It's been nearly a decade since I used one a lot at work. We really built up our EE department, why have a physicist bumbling around on that stuff when you've got electrical engineers!
Similar threads
