Swapped the horn out to something more appropriate to the vehicle’s size. Easy swap, doesn’t even deserve a DIY if I’m being honest. Tip: The pins push in then just pops out, allowing you to remove the access panel to the horns in 30 sec, if that.
The mounting arm on the horn you buy may need to be repositioned to vertical.
