Heads Up Display won't keep the position I set it in.
RCH
4
Maine
2025 Land Cruiser
2025 LC. The HUD doesn't keep its position when I:
(1) change seat position and move it back or
(2) turn the car off and back on.
Is the HUD supposed to save its position with the seat presets?
My wife has to reset the HUD position every time she gets in the car. Annoying.
That has driven me nuts in our RAV4 Prime for years, and nothing has solved it. My wife doesn't really drive the LC much so there hasn't been any need to change the position significantly, but it certainly hasn't returned all the way to the bottom the way the RAV4 does.
I believe the HUD is supposed to reset with the key being used, but it is something you have to set up in software (and also adjusts seats, steering wheel, and mirrors). If those aren't working for you, you probably need to dig into the manual and get that feature set up, then it should all work. Keep the second key far away when you set it up the first time.
No issues here. Once I set my seat and mirrors then went into settings and set the height and brightness. Have HUD in my Audi A6 and Honda Accord also. Never have I had it drop off or down like you have mentioned. My LC is a premium, not sure if that makes a difference. Also, once I got everything set the way I like; I went into Vehicle custom setting and under door exit and enter. I shut seat retrack and steering off.
