This should be an easy one. Where is the location of the air filter under the hood?
I can't seem to find it.
Passenger side engine bay towards front headlight in front of fuse boxThis should be an easy one. Where is the location of the air filter under the hood?
Not sure what you mean?Subbed.
โSubscribedโ. It means I want the board to add this to what Iโm following. Easiest way to do that is to make a post, but I didnโt have anything useful to say.Not sure what you mean?
There is only what I showed in the image.There should be a filter. The filter is kinda purple.
Itโs a square filter.There is only what I showed in the image.
Would you mind taking a picture of yours and showing what yours looks like?
Mine just has a pad that is bolted down with these plastic things.
However, there is no filter that I can see.
Certainly not a filter that looks like the new one I have in the first image.
Did your filter get stuck to the lid?Here's a picture with it opened. You can see there's just a pad that is fastened down.
However, I don't see the filter there.
Holy @#!? YES! LmaoDid your filter get stuck to the lid?
Thank you !!!I just looked at your picture. Itโs stuck to the top. Mine was stuck
They are about $25.00 at the dealer.Since we're on the topic and I bought the wrong replacement engine filter.
Does anyone have an Amazon link for the 2024 Land Cruiser engine air filter?
I live in the country. The dealer is about 1 hour each way. (Without traffic)They are about $25.00 at the dealer.
