Creaking sound in steering wheel
tbounds02
281
189
Ms
22 tundra
Has anyone else noticed a creaking popping sound in steering column when still still and turning steering ?
I have started noticing this when parallel parking extreme turning of steering wheel ?
so nobody is experiencing any noise while turning steering wheel sharp to left and backing up ? Its not the brake squeal , but more of something in the steering control arms ?
no. But floor creaks a lot. First year woes..... Brakes squeal, there's a squeak somewhere I cant pinpoint..... I have a list going.... not exactly Toyota quality I'm used to....
Not experienced this issue. I have recently noticed what sounds like an intermittent hum from the brake booster. This is not the typical brake booster cycling I'm used to hearing. Like a constant humming until brakes are no longer pressed. Does not always repeat on startup.
It is almost like a clunking sound , If anyone had an older GM truck that had the noise in the steering column when turning steering wheel it is much like it. The fix is to grease the shaft in steering wheel or replace all the bushing in steering column
