Carista Full Customization List
MrRum75
22
29
California
2024 Land Cruiser
I made many changes last night to my 2024 LC/LC with Premium Package. Everything worked except for the Rear hatch walk away kick sensor even though I enabled it. Not sure if anyone else has had any success with that?
Carista EVO Bluetooth OBDII Scanner Amazon.com
Obtained with Carista 8.9.2 for iOS., Download app: ‎Carista OBD2
I've added the Top Categories of the App in the photos, each has their own subcategories and not all are included.
Customize
*The following settings were available specifically to your vehicle using Carista:
Chassis & Engine
Active Noise Cancellation (ANC)
ON / OFF
Engine Sound Enhancement (ESE)
ON / OFF
Dings & Warnings
Warn when doors opened with headlights on
ON / OFF
Seat belt warning ding (driver)
ENABLED / DISABLED
Seat belt warning ding (front passenger)
ENABLED / DISABLED
Seat belt warning ding (rear right passenger)
ENABLED / DISABLED
Seat belt warning ding (rear left passenger)
ENABLED / DISABLED
Seat belt warning ding (rear center passenger)
ENABLED / DISABLED
Seat belt warning ding (third row left)
ON / OFF
Driver Assist
Blind spot monitor
ENABLED / DISABLED
Heater & A/C
Temperature dial calibration
-2 °C (28.4 °F) / -1 °C (30.2 °F) / NORMAL / +1 °C (33.8 °F) / +2 °C (35.6 °F)
Instruments: Displays & Nav
Instrument lights restoring sensitivity
DARKEST / DARKER / NORMAL / LIGHTER / LIGHTEST
Display odometer after ignition is turned off for…
30 SECONDS / 1 MINUTE / 10 MINUTES / OFF
Microphone sensitivity
4
Speaker volume
5
Instruments: Heads-Up Display (HUD)
Image distortion in heads-up display (HUD)
CONCAVE HIGH / CONCAVE MEDIUM / CONCAVE LOW / DEFAULT / CONVEX LOW / CONVEX MEDIUM / CONVEX HIGH
Lights: Automatic
Auto headlights activation threshold
Lights: Exterior
Daytime running lights
ON / OFF
Lane-change turn signal auto-flasher count
OFF / 3 FLASHES / 4 FLASHES / 5 FLASHES / 6 FLASHES / 7 FLASHES
Turn signal click volume
LOW / MEDIUM / HIGH
Coming-home lights duration
OFF / 30 SECONDS / 60 SECONDS / 90 SECONDS
Turn on marker lights when vehicle is unlocked via remote
ENABLED / DISABLED
Lights: Interior
Turn on interior lights when you shut off engine
YES / NO
Turn on interior lights when smart key in range
YES / NO
Interior footlight (bright when doors open, dim when driving)
YES / NO
Locking: Automatic
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / 60 SECONDS / 120 SECONDS
Locking: Beep & Blink
Blink hazard lights when vehicle is locked via remote
ENABLED / DISABLED
Locking: Doors & Alarm
Max number of consecutive lock/unlock cycles via touch sensor
UNLIMITED / 2 TIMES
Warn (beep) when a window is still open when locking doors
YES / NO
Locking: Smart Key
Touch-to-unlock-doors minimum duration
OFF / SHORT / MEDIUM / LONG
After locking with smart key, don't allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / 2.5 SECONDS / 5 SECONDS
Smart key location to start car
FRONT AND BACK SEATS / ANYWHERE IN VEHICLE
Mirrors
Auto fold side-view mirrors (req. power folding mirrors)
WITH IGNITION / WITH DOOR LOCKS / DISABLED
Parking Sensors
Activate parking sensors in neutral (N)
YES / NO
Front center parking sensor range
SHORT / LONG
Front corner parking sensor range
SHORT / LONG
Seats & Steering Wheel
Seat airflow level
NORMAL / SILENT (HIGH) / SILENT (LOW)
Easy entry/exit
DISABLED / RETRACT STEERING WHEEL FOR EASY ENTRY/EXIT / TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT / RETRACT AND TILT AWAY STEERING WHEEL FOR EASY ENTRY/EXIT
Trunk
ENABLED / DISABLED
Trunk front seat switch button
SHORT PRESS / LONG PRESS
Rear hatch open/close with "one motion"
ON / OFF
Rear hatch remote press
SHORT PRESS / 2 SHORT PRESSES / LONG PRESS
Windows & Sunroof
Open windows and sunroof via long-press on remote
ON / OFF
Open windows and sunroof by turning and holding key in door lock
ON / OFF
Close windows and sunroof by turning and holding key in door lock
ON / OFF
Wipers & Washer
Auto-enable rear wiper when front wipers on and reverse gear engaged
SWITCH REAR WIPER FROM INTERMITTENT TO PERMANENT WIPING WHEN IN REVERSE / TURN ON ONCE / DISABLED
Enable rear window wiper when trunk is open
ENABLED / DISABLED
Other
Panic function on remote
ENABLED / DISABLED
